Hot H2O only lasts 5-10 min. Then takes 1.5 to 2 Hrs. to recover ! HELP!
Could be a number of things. The first thing to do is to verify that you are getting 240 volts at the upper thermostat, and right on the element terminals. Let me know if you do, and we'll go from there.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
SOURCE: I have a Rheem EcoSense hot water heater and all
Have you try to reset the power to the heater?Then turn the hot water facuet on to see if it will start up.
SOURCE: My Rheem hot water heater stopped putting out hot
If you are not familiar with the element, I would get someone that is familiar with one and have them do it. It's not something I would recommend you do based on your question. There's electrical, pressurized water tank, and a whole lot of water that may cause you to have a worse bad day.
SOURCE: rheem tankless water heater error code C4 13??
check diaphrapm valve or micro/switch best of luck
SOURCE: My rheem water heater doesn't seem to be heating
try setting the bottom 10 degrees hoter than the top could be in short cycle (thatis the bottom calls for heat on the bottom element and set too close so goes back to top and cycles off
SOURCE: Not heating water hot enough or as much water.
You probably have a bad heating element. Probably the upper element.
