Need to get pass my password screen on htc chacha so i can recover my contacts
Defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
SOURCE: hello sir, i have HTC 3400i mobile phone i want
There is software named autosync in your cd which you have got while purchesing.Please install that software on your pc and connect the phone to pc.Automatically you will get backup.
SOURCE: screen password
you have to do a hard reset but it will restore to factory settings erase everything but if no other option, press the send and hang up button and hold while pressing the reset button at the bottom.
SOURCE: need to get contacts from phone to computer and my screens broke
hey mate you need active sync on your pc- it should have installed in the first connection (maybe you got a cd with the HD with it on it or try searching for it) from here you connect up using the usb cable that also goes in your power pack and connect it up and choose active sync on the mobile (if touch is still working) or if not it usually is preset to choose active sync from here it should start syncing all your phone info to microsoft excahnge automatically (i had to set up an excahnge connected it to my hotmail account/uni account) from here next time u say reset your phone (hard reset) or flash it or get a new windows mobile phone (all same software ie samsung omnia and htc touch hd both windows 6.1) it will automatically resync all your contacts onto the phone (as long as its connected on active sync)- hope this helps a bit
SOURCE: my HTC Touch phone screen is not working
You will have to try and remember your password, otherwise you will have to do a hard reset. turn off phone, remove memory card, turn on phone by holding down power/green/red all at the same time, this will loose all your contacts and settings and resor back to new.
Dan
SOURCE: how can i move my contacts from SIM to phone in
go to contact you will definetly get out your problem best of luck
http://download.cnet.com/Password-Master-3/3000-20432_4-75790100.html
Get a password vault like the one I linked above. Then, save all your credentials in there as you make them.
