The rear wiper has its own pump motor. pull the hose from the wiper and have someone engage to see if there is a clog. do the same at the motor. if bo liquid comes out then its the pump. also check fluid level in reservoir as well as a possible secondary reservoir
Sprayers are clogged up. You can clean out the sprayers with a needle, some have two holes so look carefully.
SOURCE: 2002 Jeep Liberty sport-- NO HEADLIGHTS OR WIPERS
check fuse in fire wall open the hood of your jp or by your gas and break pedal
SOURCE: Windsheild Wiper Fluid will not squirt on windshield
While you were filling the tank you may have disconnected the pump wires. If you can hear the pump activating when you use the switch then the pump may have gotten clogged , check for sediment in the tank. For the person with the mustang - if its only coming out of one side then its a nozzle clogged or a pinched hose.
SOURCE: 2003 Jeep Liberty rear wiper does not work
how is it not working, entirely not running, or just doesn't come in contact with the glass?
SOURCE: standard size tires for 2002 jeep liberty limited
should be a sticker with sized right inside the door jam or on door near latch.
SOURCE: 04 jeep grand cherokee limited, my four windows dont work
with the windows it obviously is something common to all four and the first item I would check is the fuse. Interior lights are controlled by the headlight switch and a worn switch can be the problem. If these are not the problem than I would want to check the wiring, specifically the ground. Ditto for the rear wiper. Fuse first. Switch second. Wiring third.
Junction block location-1999-04 Grand Cherokee
Inside your Jeep.
