Sony Ericsson K750i Cellular Phone Logo
Anonymous Posted on Jan 11, 2009
Joystick was not working properly, the left,right,down and up keys are many times struggles to work the option, some times displays turns off automatically while working, but on that time i can attend the incoming call and message but cant see the name.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jan 11, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
71
Points
You can restart the phone 5 times before play games
My Nokia 3230 joystick is not working properly. It selects the first option even if i try to move it up, down, right or left. Please tell me the solution. Thanks in advance.
your problem may cause a damage joystick or the top board of your may be damage or loosing connection try to dismantel it properly then remove and put back again all the connection of the top board.
Jul 30, 2011 • Nokia 3230
How to change setting picture just opposite
If opposite means that you want to rotate the image or picture for projector mount in the ceiling.
KEYS location: (keys are located back side of the projector there is 2 keys 1 for menu and second is a joystick witch have 4 arrow keys and center press is a enter key)
Press MENU button to display the menu screen.
then use joystick UP and DOWN to select the OPTION menu. Press joystick for ENTER to display the option screen. Then press joystick UP and DOWN to select INSTALLATION.
Then press joystick RIGHT and LEFT to select your required image rotation there is four type of rotations.
1. FRONT DESK
2.FRONT CEILING
3.REAR DESK (A translucent screen is required for rear projection)
4.REAR CEILING (A translucent screen is required for rear projection)
If opposite means negative to positive so there is no any setting in your projector witch is chang your picture or image positive to negative.
My panasonic PTLB60NTE shuts down after couple of minutes when I use wireless mode. How can I solve this?
There is three indicators lights on the panel
1. lamp indicator.
2. temperature indicator.
3. computer input indicator.
If your projector shutdown itself without given any indication its mean that your projector function POWER OFF TIMER is on. You can off this function.
How: (two keys back side of projector one is menu second is a joystick witch have 4 arrow keys and center press is enter)
press MENU button to display the menu screen and then use joystick UP or DOWN to select the OPTION menu. press joystick to ENTER and then use joystick UP or DOWN to select POWER OFF TIMER use joystick RIGHT or LEFT to select DISABLE then press MENU two times to exit the menu.
If your projector shutdown itself with given any indication then
If LAMP INDICATOR flashing RED then lamp circuit failure its need to be repair or replace.
If TEMP INDICATOR flashing RED then the temperature inside and /or outside the projector is abnormally high.
CAUSE: The ventilation opening are covered. The room temperature is too high. The projector is located at high elevations (above 1400m)
REMEDY:clean the air filter. Remove the object from the ventilation openings or clear around the projector. Set the HIGHLAND option to ON
Etrex legend joystick problems
could be the hardware switch itself
2answers
Curser traveling to top of screen all the time,
Disable the joystick mouse in the center of the keyboard. Doubleclick Mouse in the Control Panel (Start/Settings/Control Panel). On the end tab, disable the thumbstick mouse. For my IBM Thinkpad, it's under UltraNav and I disable TrackPoint.
Z525a screen comes on but stays vacant.
If you have access to a laptop computer that has an Infrared Port or Bluetooth communications, you can download your videos and picture files via either of these two methods. I use an old IBM Thinkpad 600 with IR port to download mine. You have to put your z525 phone into Infrared mode first, its kind of tricky with out seeing what you are doing. First, open your phone, press upper right (-) sign to get menu, click joystick control down 2 times then right 1 time. next press upper left (-) sign to select. next joystick right 4 times, and down 1 time. press upper left (-) sign, then joystick up 1 time. press upper left (-) 1 time. Your Infrared Port will now be turned on, and your I.R. enabled laptop can now receive the files from your phone. Close your phone, open it again, press upper right (-) , press joystick down 1 time, then left 1 time, then press the joystick center select button 2 times. Joystick right 1 time, press joystick select 1 time. press upper right (-) 1 time, joystick down 5 times, joystick right 1 time, joystick down 3 times, joystick center select 1 time. Hold the lower left corner of your phone toward the I.R. port of the laptop, it will receive the first photo file in your camera pictures file. Another possible method would be to obtain a usb connector cable for the z525 phone to connect it to your computer. Using the usb cable the computer would recognize the phone, you could click on the phone icon, under "MyComputer" and transfer the files to your hard drive. I hope this helps. -Mike
Steps to forward inbox texts to email with white screen problem?
First open your phone. Press upper right (-) key to get menu. Press joystick up 1 time to get Messaging. Press joystick center select button 1 time, then down 1 time for "Inbox" (or down 3 times for email). Press center select 1 time, joystick down 1time for Inbox, center select for first message. Press upper right (-) key for "More", then joystick down 2 times to get "Forward", press center select. Press upper left (-) key to "Continue", press joystick up 1 time to get "enter email addr." Press joystick center select button, and enter the email address you want to forward the message to. After you have typed in the email address, press upper left (-) key "OK" 2 times to "Send", if you normally enter a password, type it now, press upper left (-) key for "OK" and your message will be sent. Hope this helps. -Mike
Sceen is blank and i need to turn off bluetooth
Start with the Z525 closed. Next open your phone. Press the right (-) key 1 time to get Menu. Click joystick down 2 times, then joystick right 1 time, & then center joystick select button 1 time to get Settings. Click joystick left 1 time, then center select button 2 times to toggle Bluetooth OFF. Close phone & you're done. I hope this helps. -Mike
11helpful
3answers
Setting my clock
I have deh 1450, turn ign on, radio off. On mine I pressed and held the top right button (audio) clock starts flashing. Set time using directional buttons (up, down, left, right) When finished I pressed the 'loud' button (bottom right of face plate to end
2helpful
2answers
New JVC Everio MG 130
Hi, to set the time or date, first press the MENU button (beside the DIRECT DVD button). Nudge the joystick to the left to select which settings you want to edit. Then go up until you reach the general options. Nudge the joystick right. Move the joystick up until you see "CLOCK ADJUST". Here you can set the correct time. The light is really easy to access. In the shooting mode (where you are seeing live video from the lense), nudge the joystick down. The light should come on. Nudge it down again to put it on Auto. It will turn on/off depending on the lighting. Nudge it down a third time to turn it off. Hope this helps!
Eric
Top Sony Ericsson Cell Phones Experts
Sean Wright
Sean Wright
Kolbrun...
ZJ Limited
ZJ Limited
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
