Question about Uniden Cordless Phone
How to set up Speed Dial on a Uniden phone?
My mother has a cordless uniden phone with no instruction manual. The model # is EXP4540. We need to know how to set up the speed dial for safety measures.
My Mom had this same problem.   I found these instructions on Uniden's website (uniden.com) under the "Owner Manuel" section.
Here you go - good luck!
Using the Speed Dial Memory
Storing Numbers in Speed Dial Memory
Your cordless phone can store up to ten numbers (up to 20 digits each) in the speed dial
memory. To store number in memory:
1) When the phone is in standby, press [memory]. The talk/batt low LED flashes.
2) Use the keypad to enter the phone number.
 (To enter a 2-second pause between numbers, press [redial/
pause]. Each pause counts as a digit. )
3) Press [memory] again.
4) Select the speed dial location where you would like to store the
number ( [0] to [9] ). You will hear a confirmation tone indicating
that the number has been stored.
NOTE:
• Storing a number to a speed dial location will
overwrite the any previously stored number without
warning.
• When storing numbers into memory and the handset is idle (i.e., no key is
pressed) for more than 0 seconds, it will beep rapidly, and then the phone
will return to standby.
Dialing a Stored Number
1) When the phone is in standby, press [talk], and listen for a dial tone.
2) Press [memory] and enter the speed dial entry ([0] – [9]) that has the stored number
you want to dial. (If you enter a digit that does not contain a stored number, the
handset will beep rapidly, and the phone will not dial.)
Chain Dialing
The speed dial memory is not limited to phone numbers. You can store any number (up
to 20 digits) that you need to enter once your call connects. This is referred to as Chain
Dialing. An example is a frequently refilled prescription number. Store your pharmacy
phone number in one speed dial and your most frequently refilled prescription number
as another speed dial. To use, once you ring your pharmacy's automated prescription
line, simply press [memory] and the speed dial number where you stored your account
number.
Erasing a Stored Number from Memory
1) With the phone in standby, press [memory] twice.
2) Press the number of the speed dial entry. A tone indicates that the stored number is
erased from memory.
Posted on Feb 05, 2009
  • georgiafi Apr 20, 2011
    how do you get the phone to be in "standby" mode?
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
Uniden DECT 2145 entering speed dial numbers to base.
1.Select phonebook number you wish to add.
2.Select 'edit' from menu.
3.Select name.
4.Select number.
5.Select Speed Dial position 0 - 9 by using Up or Down keys.
6.Press select to finish.
7.When finished you see 'Done!' and hear beep.
Posted on Nov 20, 2017
SOURCE:
Need to know how program mew phone number head set for speed dial.
The procedure varies from phone to phone. Since you neglected to specify the model of your Uniden cordless phone I can only suggest you select it from the list beginning here to download a copy of the manual.
Mar 30, 2011 | Uniden Cordless Phone
How do I turn on my speakerphone for my Uniden EXP4540?
Sorry, Uniden EXP4540 2.4 GHz does not have a speaker phone feature. The cordless phone features AutoTalk™ and AutoStandby™. AutoTalk™ allows you to answer a call by just removing the handset from the base so you don't have to waste time pushing buttons. AutoStandby™ allows you to hang up by simply returning the handset to the base. You can check it's manual with this link http://www.uniden.com/pdf/EXP4540om.pdf.
Thanks for using fixya!
Mar 30, 2011 | Uniden EXP4540 2.4 GHz Cordless Phone
Speed Dial
Select the model of the phone from the list at
http://www.uniden.com/index/manuals_results.cfm?cat=1
May 20, 2010 | Uniden Cordless Phone
I want to change speed dial nos. don't have manual for instructio
You should be able to download the appropriate manual from
http://uniden.com/index/manuals_results.cfm
Jan 07, 2009 | Uniden 5.8GHz Expandable Cordless Phone...
Setting the speed dial numbers.
When phone is on standby press memory-the talk led lite should flash. enter the phone # you want to store then push memeory again. Select the speed dial # you'd like to use for this phone # (0-9) then you should here a tone indicating it was successful. Let me know if this works for you-it should!!
Nov 12, 2008 | Uniden Cordless Phone
Uniden Cordless Phone Logo
8,378 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
