Tv picture and sound resume for about 15 minutes and cycle repeats. Picture fine. Bulb? Ballast, Power Pack?
SOURCE: sony grand wega KDF-E50A10
The looks of the bulb are no indication that it's okay. How many hours of operation do you have on that bulb? The bulbs are average rated for 5000 hours, but its been my experience that they usually last on average 3000 hours. Try replacing the bulb and then check and rest the buld hours counter.. Best place I've found for purchasing the bulbs is DLP lampsource. They'll sell you just the bulb without the housing at a dramatic savings. http://www.dlplampsource.com/
To display the lamp time press [ 2 ] nine times.
to reset press [ 3, mute, enter.] Or with the set in standby press [ display, 5, vol up, power ]
then press [ jump 3.]
Hope this helps!
Bill
SOURCE: Samsung HLP4674W - changed bulb - still no picture - lights flash
If the lamp has been replaced I would think the Lamp ballast would be most likliest followed by the color wheel and then the Digital board. You can get any part needed for your model at www.tvrepairworld.com just leave them a email they respond quickly.
SOURCE: Problem turning on
Check that the large fan in the back is working when you turn it on. If not, the set will shut itself off
SOURCE: The picture goes off, the power/standby light
Sony KDF-60XS955 picture goes and power/standby light light flashes
Most likely you have bulb failure. First step in troubleshooting is "Change the Lamp or Bulb". Lightning, power line bumps and collisions with vacuum cleaners can all shorten lamp life. Rough handling in shipment can also happen without your knowledge.
+90% of all Sony LCD Rear Projector "No Picture or Intermittent Picture" faults are related to bulb failure.
If new lamp does not improve the situation, then hands-on troubleshooting by someone that has parts and knows how the unit works is the only practical remedy.
easyab
After replacing bulb, TV returned to normal. Found an unbelievable deal at 40.00
