Specifically, I need to know where the pink, black and red wires coming from the heater coils plug into. The red wire runs from one terminal of the heater coil to one of the circuit breakers. The pink and black wires were unplugged and hanging loose when I opened the cover of the unit. I recently bought a mobile home that had this unit.
SOURCE: Jenn-Air JED8430 Electric wiring confusion
On Cooktop From Box
Black to Black
Red to Black w/red stripe
White to Ground
Green to Cooktop frame
SOURCE: Intertherm E1EH-015HA FURNACE no heat
Sounds like a downflow electric furnace? If so it sounds like you have 15kw worth of electric heat, you might have a defective heating sequencer, witch is what they call a dual on one plate.
SOURCE: maytag ice dispenser wiring diagram model MSD2456GEB
apc...appliance parts center has a good web site that might get you a wiring diagram. or your local appliance supply store might.
SOURCE: Back of Fridge icing up - Miele KFN8762SDED
The problem I see is that there are things blocking the back of the freezer and what happens is all of the cold air from the freon is forced back into the freon and the freon will release the cold where ever it can. Try re-arraigning the inside of your freezer/fridge. If you have any questions Ask me and I will continue troubleshooting.
RCF
