When I turn on the TV, the sound immediately starts increasing until the volume is at the maximum. If I push the volume down, it responds but when I quit pushing the volume button, it immediately goes right back up. Also, the source keeps changing without me hitting any buttons.
Hi deborah card,
Lets first make sure your remote is not causing your problem,
Look at the light (led) on the remote, is it lit and pulsing?
If not you are having a problem with the control panel,
Have you recently cleaned your tv with a liquid?
If so you will need to dry the panel with a hairdryer, unplug the power from the tv, put it on low heat and hold it about 6 inches from the panel for a few minutes. With the tv still unpluged press all buttons on the panel a few times then plug back in and try it. Let me know if this helps and please rate this solution. lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Thanks for the reply.
1. The remote is not the problem. I removed the batteries from it to make sure and the TV still did it.
2. No cleaning and I took off the back panel blew all dust out.
Also, I've figured out how to temporarily fix the problem. I turn on the TV and the sound immediately starts going up so I use the remote and push mute, then I immediately un-mute the TV and it sticks on whatever volume it was last on.
Possibly the TV is possessed:)
the volume on the tv goes up and down randomly
