I have a Kenmore 95115102 and all I did was manually cycle the door latch a few times. It's at the top of the chassis when the door is open.I have a Kenmore 95115102 and all I did was manually cycle the door latch a few times. It's at the top of the chassis when the door is open.
You can't post conmments that contain an email address.
Try owner's manual, troubleshooting and the F5E0 error code. It may help, otherwise google the error code, or no owners manual? try https://www.manualslib.com
Hi Thanks for using FixYa. This error means that
you’ll need to check the door latch/switch and replace the part that has gone
bad.Please do rate the solution
if the issue is resolved or post a comment for further assistance. Thanks Rylee
it means that your switch on the lock is stuck in the wrong postion literally just fixed mine....lift up the heating elements of top and remove the 8 or so screws that are around the perimeter of the and it reveals the lock switch, myself i just kind of pushed on it to get it to go back haha...i pushed the lock part towards the left side and it slowly moved back on its own....
Hope This Helps you!!!
F5 - E0 F5 - E1 and E2 -------- this all codes relates to ----- Check door/latch switch ------------ clean it and check if stiil the same problem ---- Replace switch if defective
