I have an insignia 32" lcd tv that has a bad power supply I have three minimelf zener diodes on the board that I need part numbers for or values! Thanks to anyone who can help.
DGJTEX
SOURCE: AKAI MLT168A Power Supply
Here are the values for the parts:
R104 and R105 are 100 ohms 5% 1 watt but you can use 2 watts.
R107 is 200 ohms 5% 1 or 2 watts.
C17 is 2200pF 10% 1Kv.
SOURCE: no picture
Had the same problem, Insignia 32 would click on then go off. About 6 months ago I found (somewhere on the net) a guy who explained that he changed blown capacitors. As I recall he even posted a picture. I found the blown capacitors and replaced them with larger capacitors (less than $20) problem solved...
But now my screen image is showing only half a picture and is pulsing on a off.
I think I'm going to make a Wii commercial......GL
SOURCE: insignia 32 HELLP
You can find parts for your TV here. If the power supply is an internal component, it is strongly recommended that it be installed by a TV repair professional.
PHIHONG - PSM210-417A-R
Rather than spend hours and time on the kit, these guys have the board in.
