Music from my phone. this only occurs while listening to a particular station. However, whats werid is that I listen to it during the moring hours (sports talk radio) and few if any problems. Then the afternoon show comes on and every few mins I get this error, constantly buffering or server is busy try again later.
Ahaaaa... sounds (no pun intended) like your "station" SERVER is getting overloaded with more users/listeners during the evening hours?
CONTACT the station during business hours and ASK to speak to "the Technical Staff" or "Station Engineer"... LAST resort is "Customer Relations"...
TELL them about your results because THEY ALL want to keep their JOBS! MORE listeners/subscribers means (usually) more SALE POWER to advertisers! More UNHAPPY listeners means 'they' go to someone else who CAN DELIVER!
ARMED with complaints ~ MOST WISE stations WILL opt for BETTER 'middleman SERVER/broadcasters' who can PROVIDE ENOUGH DATA to satisfy ALL who want to listen.
Anthony
SOURCE: listening the FM Radio on laptop
like the guest said uptop there is no way do to it
sorry
~Temp
SOURCE: fridge condensation - freezer thawing
OK now I'm wondering are theses numbers your getting 4 -9 the actual temps of the refrigerator and the freezer? and do they feel this cold and correct to you? I know the refrigerator side shouldn't be below 34 or so and definitely not below 32. If this is correct and the numbers are not settings but temps. (Now if you have a touch pad its electronic. If it has knobs it has a separate defrost and thermostat and are electro-mechanical)
If electronic Your control board and possibly defrost control are out.
It would more likely be the sensors going to the board(s) It will both sensors have the possibility of causing your problem. 1 will control the run of the compressor (and this one could and probably is connected to the inside coil) and 1 will control the air damper tween the refdg and freezer compartments, and may turn on the inside fan operation too.
(this would be my first suspect if these are degrees numbers). Look at the thermostat control see if it is attached to the indoor coil (usually the tube leavign the indoor section. If its not attached its not sensing the coil temp and when goes into defrost wala its not senmsing temps like its designed to do. Look for a broken clip or possible a plastic wire tie that holds this sensor in place.
Please get back to me with what you see - find on this look up.
SOURCE: hello my samsung D880 earpice and speaker suddenly
check to make sure your earpiece jack tip is good make sure nothing
is stuck in the jack ie lint,trash ect
SOURCE: How to record conversation with a caller
when the call is active, select option> you will get the option for recording the call conversation. And the call will be saved under voice record folder
