2001 Chevrolet Prizm Logo
B Rich Posted on Oct 28, 2017
Problem with 2001 Prizm '01 Prizm 5 spd: piston ring change possible without pulling engine (Toyota 1zzfe) Posted by Guest on 11/29/2012 Details '01 Prizm 5 spd: piston ring change possible w
Problem with 2001 Prizm '01 Prizm 5 spd: piston ring change possible without pulling engine (Toyota 1zzfe) Posted by Guest on 11/29/2012 Details '01 Prizm 5 spd: piston ring change possible without pulling engine (Toyota 1zzfe)????? Drinks oil and the head is being replaced. Can the ring change be made without pulling the engine?
5 Related Answers
Anonymous
  • 520 Answers
  • Posted on May 07, 2009
SOURCE: oil pump and busted head gasket
You should not have to pull the engine to do this project. However there is a cross member under the engine that will need to be removed first. Once this is done you need to un-bolt the motor mounts. Then you will need to lift the engine with a hoist. Now you can remove the oil pan and then the oil pump. Hope this information helps. Good luck.
Anonymous
  • 60 Answers
  • Posted on Jun 22, 2009
SOURCE: 98 chevy s-10 2wd is it possible to change the oil
Yes it is possible but you will have to get about six inches of clearance so the pan will clear the oil pump pickup
Anonymous
  • 10 Answers
  • Posted on Dec 22, 2009
SOURCE: Is there ANY way to change the oil pan gasket on a S10...
Remove motor mount bolts and rear transmission crossmember bolts or nuts,suppport engine/trans. see if u have enough clearance between pan and axle remove pan. if not, split the exh away from the manifolds. worth a try
Anonymous
  • 2317 Answers
  • Posted on Oct 24, 2010
SOURCE: I have a 2001 2wd
You can do that. I would check cylinder wall taper and ring gap. If the knock is coming from a rod bearing, I would plasti-gauge that journal first to make sure that the crankshaft doesn't need turned. Besides that, you should be ok.
khardaster
khardaster
  • 4 Answers
  • Posted on Apr 23, 2012
SOURCE: 5.3 Lost oil pressure to top of engine after head change
you need to check i"m not positive on that head gasket pattern but if its upside down you could have covered a oil port causing your oiling problem
Can the engine piston rings be changed in a 2001 vw golf 1.8 turbo without removing the engine from the car?
Yes you can be only you need to remove the head and sump and keep the crankshaft clean
2answers
How to replace a fuel filter in a 2000 Geo Prizm
same as a 2000 toyota corolla. just diffr, badges.
the engine , in car defines what fuel setup you have on most cars made,
1ZZFE 1.8L DOHC EFI,
today nobody changes it for fun or service.
its only changes if its bad now. (epa laws moved it)
did you first try to buy it,? you;d have seen its not like you think.
its here,
id leave them alone , until fuel pressure drops, if ever.
the fsm nor oper guide lists it to do random service,
so why are you asking this.???? the filter is here. 2
pump is 3
2answers
What is the Head bolt Torque pattern for a L4-1.6 Liter Engine?
92 toy corolla engine. it is ,not 93+ clear as day.
that is a toy 4afe engine, fact.
1.8L is the 7AFE engine, and happened in 1993.-97
so i dont need the VIN. its the early 1.6L
in 98 the 1zzfe. engine... so is not that either.
mitchells has this. weve posted it vast times
4a head,
26151097-0i5bdmiyahenqhfvpxdzaarp-5-0.jpg the prev. page is the OFF'ing sequence. FY:
02 wiring diagram
you posted 3 times, and all 3 times same question
but if you read your other posts, bingo.
you never said the symptoms
nor said if it is the front or rear 02 sensor.
so i toss coin and land FRONT. B1S1.
i did answer for all 3 engines,
documented the
oxygen sensor B1S1 on all 3 ECU's
so , look.? at them.?
2005 toyota corolla blowing smoke
Blowing black smoke means fuel mixture is too rich, possible choke is stuck partically closed.
Blowing white smoke especially driving off the traffic lights indicates either worn valve guides or worn piston rings. Valve guides require the head to be removed to replace valve guides.
Replacing piston rings means a major engine repair. It maybe better to get a reconditioned motor than replace worn piston rings because other worn engine parts should be replaced at the same time.
96 geo prizm is burning oil. what is the problem?
Depending on the mileage, worn piston rings are the most likely cause. There are also numerous places on these engines that leak - valve cover gasket, distributor seal, cam seal and oil pan are the most common. You can try a heavier weight oil the next oil change. If you're current using 10W30, try switching to 10W40.
2answers
Toyota Tercel had engine replaced now it smokes alot. The details are rather lengthy and if possible I would prefer to not have this posted online at this time, but do have several questions regarding this...
It's an old engine out of another car I assume. You either have worn oil rings or the valve seals need replacing. Try using STP oil treatment or Wynn's oil treatment for the time being. This should help. Also try 10W40 oil at your next change. Short of a rebuild, it's about the best you can do. Good luck!
1helpful
Would a 2006 corolla engine fit in a 2001 corolla if it has the same engine code 1zzfe
if its the same model car as in 2001 they changed till2007 so it might fit
2helpful
2answers
2001 Toyota Corolla, Burning Oil rapidly
hi, the main cause of major oil consumption is due to cylinder wall deterioration. this is caused be bad piston ring sets that tend to chip of tiny pieces of the cylinder walls over a long period of time. this will start to show in engines with high millage. this will also lead to compression loss as well if it is not fixed soon.
To fix this issue within the cylinder walls, they will have to be machined and a new set of piston rings will have to be fitted around each affected piston. this will stop the oil from leaking into the combustion chamber and it will restore the compression rate as well.
4helpful
4answers
Take your vehicle back to your mechanic, and have him perform a DRY, then a WET compression test. Please provide both readings back to me. In the meantime, ask him what it would cost you to him replace the piston rings. This is your problem. The 2 tests will simply verify me thinking.
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
