SOURCE: my card is not detected
It would be a good idea to test the memory in another PC, if the problem continues, the SD has a file system that isn't recognized by your operating system or it has a bad file allocation table, if can be read only from a phone, camera or PDA , and it has data, you can use the corresponding device acting as reader connected to PC using its USB cable to retrieve your data from the card.
SOURCE: Micro SD 2 GB just stopped working
I had this same issue added music to my card did a safe remove from my comp. placed in phone and it stated "No memory card inserted" and wont read in adapter in computer Im so Sad i lost all my pics/memories :( it just means that the Card is Fried (Burnt Out) no way to fix this their just like SIM cards In 3G phones and if the copper bars get scratched or bent just the slightest bit it kills the SD card.
SOURCE: sandisk micro sd card forget password in nokia
Try putting the memory card in your PC and formatting it from My Computer.
If you have a camera that takes this kind of card, you can try to format the memory card from there as well.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
SOURCE: i forgot my micro SD sandisk 2GB memory card password
For Nokia s60 1st and 2nd edition phones.
1. First Install FExplorer in your phone memory.
2. Got to drive C: , you will find a file called mmcstore
3. Send it to your pc directly and open it in notepad or rename the file.
4. At the end of the file you will find your password.
For Nokia S60 3rd Phones, Nokia N-Series and Nokia E-Series
There is almost no way yet known to hack the memory card password in
case of these types of phone but there is a way to do it some of the s60
3rd edition phones and almost all the E-series phones.
The remote lock option in E-Series phone allws you
to unlock your phone by sending a sms.
The only thing you have to do is to activate this
feature by going to Tools | Settings | Security | Phone and SIM |
Allow remote lock menu. The password of your memory card will
be your remote lock message.
So you have to just send a sms containing your remote lock message
that will automatically change your memory card passsword.
SOURCE: i forget my memory card
does it have a switch on the outside, if so flick it It should have a little nubby switch right there. You pull it down to lock, up to unlock. if not then You can replace the switch by placing a piece of tape over the gap in the unlocked position.
