Question about Sunbeam 722 Auto Shut-Off Heating Pad Heater
F2 Fault Code On Heating Pad
What is causing the display F2 on my Sunbeam Heating Pad
  • 11 more comments
  • Anonymous Feb 09, 2009
    same problem
  • Anonymous Apr 02, 2009
    WOW - I wonder how many of us have the same problem! I stopped using for awhile, then started and it worked for a couple of days, but now get the F1/F2 errors
  • jq1301 Apr 03, 2009
    Heating pad worked ok for a while, but now all I get is F2 on the screen after about 5 monites, Very frustrating.
  • Anonymous May 04, 2009
    Same error here. Started getting the F1 error. unplugging it and plugging back in seemed to fix it temporarily. I am now getting the F2 error which does not clear after unplugging it. Problem started after only a few days with minimal use (5-6 hours total)
    Really nothing new to add...I think it might be a fuse issue (do these things have fuses?)
  • Helen Call
    Helen Call Jan 02, 2015
    I don't know if my solution will apply to anyone else, but it might. Each of these newer Sunbeam Controls are coded to work with a specific blanket. I own three blankets so I was able test it out. Each control,blanket will only stop flashing the F2 error if you plug it into the control that came with it new. I hope this helps someone. This obviously means you can't use the same control/blanket with a new one you buy. Retarded right.
  • Jimmy Kneifl
    Jimmy Kneifl Feb 07, 2017
    my controls were plugged in upside down. i hope this helps others.
  • Kristen Manchester
    Kristen Manchester Dec 04, 2017
    My blanket was plugged into the outlet while I was trying to connect the controller to the blanket and F2 kept flashing. I unplugged both the blanket as well as the outlet plug. Then I connected the controller to the blanket THEN plugged the blanket into the outlet LAST and it worked! Hope this helps!
  • lldenney Dec 25, 2017
    The blanket plugin was loose. I plugged them back in blanket first, then wall.
  • Kimberly Schroff
    Kimberly Schroff Feb 10, 2018
    OMG you're so right! It worked! Thanks so much!
  • Amy Largay Oct 14, 2018
    Unplug everything... then plug the power to the pad in first and then into the wall second. That is what worked for me.
  • SAJ65 Nov 25, 2018
    I just tried your suggestion and it is working well!!! Heating pads are expensive so thanks.
    saj65
  • Renaissance Woman Jan 19, 2019
    New Friend:
I am trying something now as I was told F2 requires you to check the blanket for wear and tear and plug it back in. 3 times doing this should be sufficient. If it still reads F2 it's "gone" Ours is new so it shouldn't be "gone" but here's what I found...Where the plug goes into the blanket there are 4 holes for 4 silver pins. I noticed the 3rd pin was a bit lower than the other 3. It will not move up with pliers so don't force it just return it. check there
Posted on Feb 02, 2010
  • 1 more comment
  • Otto Ignatcio Feb 07, 2013
    I took an emory board and cleaned the contacts. The heating pad has worked since.
  • Marcia Lawrence
    Marcia Lawrence Nov 04, 2013
    I took Otto's advice and now mine works too. Thanks, Otto!
  • Christine Lupton
    Christine Lupton Nov 05, 2017
    First, I plugged the cord into the blanket, which I had forgotten to do. F2 was still flashing, so I cleaned the contacts with an emory board, then unplugged the blanket from the wall, and replugged, and it is fixed. Thank you for your suggestions! (I also noticed that the third pin on my 2016 blanket is also a bit shorter.)
    New Friend:
  • 5 Answers
When my Sunbeam heating pad showed fault code F2, I unplugged the cord where it connected to the heating pad, blew out the accumulated dust, and plugged it back in. After that, it worked fine. No more fault code.
Posted on Aug 10, 2013
    New Friend:
The two "solutions" listed here had to do with electric blankets, not heating pads. So my time was wasted here and problem not solved.
Posted on Apr 09, 2011
    New Friend:
ARGH!! I went online hoping to find an answer to this problem only to find a BUNCH of people with the same issue... I am SOOOO sad. I had a queen and moved to a king so I had to purchase this one... NOT happy. I love a heated bed... I mean, really I LOVE it. Now I am stuck with this stupid "F2" which sometimes can be fixed with an "unplug, plug" and sometimes not. Thinking about just taking it back to Costco and trying a totally different product. So sad.
Posted on Dec 02, 2009
  • Lynniepooh Nov 20, 2010
    Just had pad number 5 do the same thing as all the others. The only reason I keep using them is they keep sending them to me, I asked this time if they had a more durable one, it's not like I'm going cartwhells with them, just laying in bed, but I got that code with each one of them. Their customer service is great though, I will say that much.
    New Friend:
I was having the same issue i tried pulling the pin up with plyers and it wouldnt come up, did a lil more research and realized i just hadnt pushed down the plug down far enough i mean you really need to shove it all the way down & it started working! Woohoo!
Posted on Dec 31, 2014
  • Joshua Warren
    Joshua Warren Jan 08, 2017
    I had the same problem, and the solution was to make sure the plug was fully seated.
    New Friend:
Ours did the same thing. We had removed the plug from blanket to put it away for the summer, and, apparently had not fully pushed it on firmly enough when we reconnected the plug.
I completely unplugged the cord from blanket, and then, firmly pushed it in until it would not go any further and the locking mechanism engaged. Turned it back on and it is now working fine.
Posted on Feb 15, 2014
    New Friend:
I had to unplug from the wall outlet and the control reset itself. My wife unplugged the blanket cord at the heating element and my side of the blanket was on so it was looking for a connection. Best practice, turn off both controls, unplug from wall outlet and then unplug blanket cord.
Posted on Feb 02, 2017
  • Ted Borda
    Ted Borda Sep 10, 2017
    This also worked for me to completed unplug and replug F2 went away thanks
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
My F2 error seemed to come and go.....at first. Then no matter how long I unplugged and replugged it- the error remained. I unplugged it, disconnected the the connecting point, blew the dust out, took my little finger and rubbed around the ports, blew hard again, re plugged it, and wallah! It works again. Yay!
Posted on Nov 20, 2016
    New Friend:
    Welcome Back:
Noted that my connector also had a recessed third pin and it also would not move. They must be manufactured that way for some good reason. Tried unplugging the power cord several times with no change. Tried pushing blanket connector in harder but to the latched position was as far as it was going to go. I saw that the pins are split in the center and some had a wider gap between the halves than the others. So I used a jewelers screw driver to open up the gap a little on all four pins. Finally, after two years of using a one sided heater I have heat on my side!
Posted on Dec 06, 2015
    New Friend:
I fixed my F2 error by opening up the controller and just making sure all the connections were good/ not corroded and then used a pencil engraver to clean off the prongs on the padconnection that had oxidized and would not allow a good connection between the pad and controller
Posted on Sep 01, 2015
6ya staff
SOURCE:
Sunbeam heating pad model 828-511 is showing F2 on controller
Hello, Pat -
I can only find that the F2 error code means there is "a problem;" not what the problem is.
I suggest you go to this Sunbeam web page for your model of heating pad:
http://www.sunbeam.com/pain-relief/back-and-spine/sunbeam-microplush-body-shaped-heating-pad-with-digital-lcd-controller/000828-511-002.html
You should see a link for "Live Chat" on the right side of the page. Click or tap on "Live Chat" to text with a Sunbeam Customer Service Representative. He or she should be able to explain the F2 error code and what can be done to correct it.
Best wishes.
Mar 07, 2018 | Office Equipment & Supplies
I have a Sunbeam model 970 heat pad. I plugged in and controller just reads F2....I can't find any instructions or know how to fix. Can you help?
Hello Carrie,
You may be able to download an instruction manual from Sunbeam directly here: Instruction Manuals at Sunbeam com
Otherwise, you might need to use their contact us feature and ask directly.
I hope this helps!
Feb 11, 2018 | Sunbeam Heating & Cooling
Sunbeam heated mattress pad blinking F2 on one side. How do I turn it off?
https://www.manualslib.com/manual/532253/Sunbeam-Sleep-Warm-Sleep-Well.html?page=12
Jan 06, 2018 | Sunbeam Heating & Cooling
Sunbeam electric blanket f2 code
hi Bonnie.
try this link and read what other people are saying about the problem you have.just scroll down on the page and read.
or this one.
Electric blanket error code
or this one.
Get F2 error code on sunbeam heating pad model cat93 contrller sw404
Dec 03, 2017 | Sunbeam Heating & Cooling
Sunbeam heating pad flashing F
Unfortunately I bought this heating pad three months ago and it too has an F in the display which I think means 'failure' but I do not know why. Also this is brand new and has worked fine for three months. Now what?
Does anyone out there have a comment to help me and this original person asking this question?
Jan 04, 2014 | Sunbeam Xpress Heat Heating Pad 2013-912
Get F2 error code on sunbeam heating pad model cat93, contrller sw404
Crimped the ends of the heating pad cord where it attaches to the pad a little then did the plug and unplug three times while holding down the on-off button and that did the trick
Jul 03, 2011 | Sunbeam 805810 HeatSense Heating Pad...
Malfunction heating pad
Same F2, quick off problem here. Then I noticed that the gray plug on the power cord was not completely flush with the connector on the pad. I shoved them together until there is no gap. The unit's worked perfectly since then.
Mar 24, 2008 | Sunbeam 805810 HeatSense Heating Pad...
Sunbeam Heating pad will not reset
I have a Sunbeam heating pad with the SW204 controller that the High light blinks when it is plugged in. I called Sunbeam and the first thing they said is it cannot be plugged into a surge protector. Next, to reset it unplug it from the wall, then unplug the controller from the heating pad. Wait 30 seconds, then plug the controller back into the heating pad and then into the wall. It did the trick. However, when I move it to the bedroom plug it does the same blinking. Sunbeam is sending me a replacement heating pad. They appear to be very good with Customer Service since it is more than a year old.
Mar 21, 2008 | Heating & Cooling
Heating & Cooling Logo
50,512 people viewed this question
Top Sunbeam Heating & Cooling Experts
Felizardo Erilla
Felizardo Erilla
Paul Carew
Pete Norton
Are you a Sunbeam Heating and Cooling Expert? Answer questions, earn points and help others
