? 14:13
https://www.youtube.com/watch?v=5frOnh58Z6M
Jun 26, 2013 - Uploaded by ShopJimmy.com
DLP TV Won't Turn On Common How to Replace Ballast DeadTV ... solid green power light plus sound ...
These blinks of LEDs are fault indications. If you wish to get more details about these blinking codes, check this link. The details are there. It is very difficult to include all those details in tables here by this window.
check the lamp if you havent changed it before that would be the easiest place to start. if the lamp is popped you will see glass pieces rolling around in the lamp.
Had similar problem. Thought it was the lamp. Examined old lamp but it appeared to be good. Ordered a new one anyway. Changed the lamp but the TV screen would not come on. It would make the usual noise as it was going to come on normally but it would cycle 3 times & then turn off. The LED lights in the front panel would indicate a defective lamp. Then read about the ballast. Changed the ballast & still same problem. Tried starting the TV without the lamp installed & noticed that the color wheel did not spin. Removed old color wheel & discovered it was broken. This appears to be the cause of all of my problems. I wish I new earlier of the test-turn on the TV without the lamp being installed & check to see if the color wheel is spinning. Would have save money on the lamp & ballast.
First you called a very inexperienced tech. Call a Samsung Pro.
Someone will have to examine it.
Get your money back for the ballast, call Samasung and get a real Tech to help you.
the power supply is not working fine. your tv needs preventive service so that semiconductor, diodes and capacitors are changed on the power supply before it switches off completely on its own.
do it fast
okay
Check your color wheel. There is a DIY guide for replacing the color wheel. Mine did the same thing yours is and my color wheel was all busted up. Unfortunately after replacing the color wheel my set continues to do the same thing, but this could mean I need to replace the ballast as well.
Les,
I'm not a TV repair guy but my owners manual states that when all three LED's or lights on the front of the TV are flashing, that the lamp needs to be replaced. Might want to look into this. Good luck!
