I got a free Intel Server Board SE7505VB2 Motherboard and was wondering if anyone knew if it supported dual core processors?
Http://www.intel.com/support/motherboards/server/se7505vb2/sb/cs-007399.htm
Page 16 of the Technical Product Specification guide;
3.1.1 Processor Support
"The Intel Server Board SE7505VB2 supports one or two processors in the 604-pin FCPGA package."
-> Socket 604,
http://en.wikipedia.org/wiki/Socket_604
-> Intel XEON processors ONLY
"When two processors are installed, all Processors MUST be of identical revision, core voltage, and bus/core speed."
-> Means you really should use two IDENTICAL processors.
"When only one Processor is installed, it should be in the socket labeled CPU1, and the other socket must be empty."
-> Self-explanatory.
That's the processor socket furthest away from the black AGP graphics expansion slot, and closest to the outside edge of the motherboard.
(Page 104, and 105)
ONLY supports Intel Xeon processors with a 400MHz, or 533MHz FSB.
Dual-Core Xeon's start at 667MHz, and wouldn't work anyway; due to different Core architecture, and Instruction Sets.
667MHz, 800MHz, 1066MHz, and 1333MHz, for dual core Xeon's,
http://en.wikipedia.org/wiki/List_of_Intel_Xeon_microprocessors#Xeon_.28UP.2FDP.29.2C_Dual_Core_2
(Scroll down just a touch, to get the Wikipedia 'banner' out of the way, or click on it's X)
Scroll down the page, look at the charts. Starts with 800MHz FSB for Dual Core, then goes 667MHz, 800MHz, 1066MHz, and 1333MHz, Front Side Bus.
Use Dual Core processors?
No.
Two Single-Core processors.
Product Guide for the Intel Server Board SE7505VB2,
(Motherboard manual),
http://download.intel.com/support/motherboards/server/se7505vb2/prod_guide.pdf
The above is a direct link to the PDF file, motherboard manual.
If it doesn't work just by clicking on it, then copy it; and paste it in your browser address bar. Press the Enter key.
(This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the above link, or press the Enter key; it may take up to 30 seconds before the first page comes up.
Didn't want you to wait a few seconds, and think nothing is happening)
For additional questions please post in a Comment.
Regards,
joecoolvette
SOURCE: Motherboard doesn´t work
Biostar Ver 1 through 7 does not support a pentium dual core. They made a mistake in their printing in the booklet! Ver 8.0 will support it.
SOURCE: Will this CPU be compatible with this MOBO?
Okay your Processor is not supported by your System Board. I will take some time and look to see what would be a good upgrade, but it may take a few days.
Ryan Frame
Creative Energy Associates Technical Center
SOURCE: i'm having intel 102ggc2 motherboard received as
Hi..
Remember that when you are replacing the motherboard, it's batter that you know what is the socket of your motherboard, so that the processor is totally fit to the socket of your motherboard. I think the motherboard you have replace have different to the socket of your processor, that's why your PC will not work.
Good luck !!!
Regards
PCmania
SOURCE: f672cr(m1610)and intel core duo?
The Acer M1610 was available with the following processors: Intel Core 2 Duo, Intel Pentium Dual-Core, Intel Pentium D/4, Intel Celeron D/4 2.0GHz.
Based on this information, It is likely that you can support a Core Duo or a Core 2 Duo, however may be limited to the 2.0GHz models due to clock and multiplier limitations on the BIOS. This may be different if there is BIOS upgrades to support faster processors.
Your best option of the above listed processors will be the Core 2 Duo, however their system specifications report that only the Core 2 with 800MHz or less Front Side Bus are supported.
Also note that the Celeron 430 is a 64bit processor, so it is not likely to work on this system either.
Testimonial: "my current processor is intel pentium dual core.i'll get a core 2 duo with 800mhz or less.thanks"
SOURCE: can intel dual core e5400 work on my motherboard?
Yes you can.
Your motherboard is LGA775 socket and supports the folowing processors:
Core2 Duo / Pentium Dual Core (yours) / Pentium D / Pentium 4 / Celeron 4xx series/ Celeron D.
