1. Press the AC button to clear the screen
2. Press and hold the Set % key until Set appears
3. Press the Tax+ key
4. Type in your tax rate (including decimal point) you wish to calculate
5. Press Set %
Step 1 pess the AC button
step 2 press and hold for two seconds the % button
step 3 input 17.5
step 4 press the % button
that should be the tax set
Step 1 pess the AC button step 2 press and hold for two seconds the % button step 3 press the tax+ button step 4 input 17.5 step 5 press the % button that should be the tax set you can check it is set correctly by pressing the AC button and then the tax+ and 17.5 should be displayed
SOURCE: Changing the % tax setting on my Casio calculator
step 1 pess the AC button step 2 press and hold for two seconds the % button step 3 press the tax+ button step 4 input 17.5 step 5 press the % button that should be the tax set you can check it is set correctly by pressing the AC button and then the tax+ and 17.5 should be displayed
SOURCE: casio MS-120TE tax rate
Found this on the casio site worked fine on my ms-120TE
1. Press [AC]
2. Hold [SET/%] key for about 2 seconds until set and a 0 is displayed
3. Press [TAX+]
4. Input the tax rate
5. Press [SET/%]
this is the link:- http://www.casio.com/support/content/AF64A1AC-193D-4650-A9A9-98BB6FE26CFE
SOURCE: How do you set a tax rate?!?!?
1. Switch off the calculator
2. Switch it on again
3. Press and hold the tax button (set %) until the display changes
4. Enter the new tax rate
5. Press the tax button (tax +)
Any problems contact [email protected] - he emailed the solution to me and it has worked.
Pam
