Cars & Trucks Logo
tariq Posted on Nov 29, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Skoda octavia service light
I need to know how to turn off the service light on a 2008 skoda octavia diesel
mr-fix
Level 3:
  • Skoda Master 405 Answers
  • Posted on Jul 13, 2015
mr-fix
Skoda Master
Level 3:
Answers
405
Questions
0
Helped
342292
Points
3488
  • david lane
    david lane Nov 21, 2016
    this doesn't work on my mk2 skoda is there any other way
g4ran
Level 1:
  • Contributor 40 Answers
  • Posted on Nov 16, 2013
g4ran
Contributor
Level 1:
Answers
40
Questions
Helped
25095
Points
57
How to reset service light indicator Skoda Octavia 2.
  1. With the ignition off, with all doors closed.
  2. Press and hold the button located besides mileage (km/h), see picture below.
  3. via-2.jpg" alt="Reset service light indicator Skoda Octavia 2">.
  4. Switch the ignition to on, without starting the engine.
  5. When on the displey appears Service now! message release the button, see picture below.
  6. 2.jpg" alt="Reset service now message Skoda Octavia 2">.
  7. Press and release the same button.
  8. Now rotate the same button to the right, in a clockwise direction, until de display will show -,- l/100km, see picture below.
  9. tavia-2.jpg" alt="Reset maintenance service light Skoda Octavia 2">.
  10. Turn off the ignition and then start the engine to see if serivce now indicator has been reset.
2 Related Answers
Anonymous
  • 1874 Answers
  • Posted on Jun 05, 2010
SOURCE: can someone pls send me
See pictures below:
Anonymous
  • Posted on Jul 01, 2010
SOURCE: skoda octavia 1.9 tdi
lods have a problem it a skoda 19tdi no power when i give it the boot 80 km only turbo kicking in ok changed air flow , washed out boost valve, would u think the timing is out
2answers
Pump relay location
From the Haynes repair manual:
'access to the relays can be obtained after removing the drivers side lower facia then remove the two plate screws (one either end) and lower the plate complete with relays'. Some relays are at the rear of the engine (the second box left to the nearside suspension strut) as your looking into the engine (under a cover)
The fuel pump works off of these fuses/relays:
Pin 5 goes to fuse no. 32
Pin 10 goes to fuse no. 34
Fuses are fed from relay no. 109
Hope this helps, a diagram of the footwell is here:
http://pics2.tdiclub.com/members/MIGOLFGLSTDI/footwell.jpg
Where is coolant sensor to computer for 96 barina swing
we have no Skoda's here, i think this is the only skoda post ever.
you need a FSM, go to SKODA dealer and ask for FSM the factory service manual, and its all there. no more guessing, or fiinding
DIY persons with a SKODA..
no engine size stated. so there will be no answers
but its near (ECT) the thermotate housing on many engines.
Where di i refill 2008 Skoda octavia 6 speed automatic transmission fluid
trans.under or side (black color ) cove , remove all cover to drain the big plug for refill (plastic red color ) the small plug for level of trans. ATF.
Skoda octavia diesel won't start after having fuel pump and injectors replaced
first fill up fuel filter with diesel . then loose injector No3 pipe
and start engine until diesel comes out .
Location of oil filter in Skoda Octavia 2006 1.9 diesel
Octavia (a4 ) remove top engine cover the engine oil filter is at front cover, big black plastic cover remove with special tool the oil filter can be remove and replace with plastic ring
Problem with Skoda Octavia Engine management light
Sounds like faulty coil. Check this on a diagnostic machine at a garage and you will get the answer.
Top Skoda Experts
ZJ Limited
ZJ Limited
john h
Are you a Skoda Expert? Answer questions, earn points and help others
