My computor did not pass s.m.a.r.t test it says an i/o unexpected error has occurred it also says file/boot/bcd status oxcoooooe9
If you want to know what this is the error code is related to
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
or click start type in event viewer press ENTER
you might be able work your way through the problem
Hope it helps.
The 303 error would indicate that your Hard Drive is failing and will need to be replaced - this is also consistent with the start-up issues you describe.
This issue occurs due to operaing system errors.
Scan your PC with an updated Anti-virus.
Scan for registry errors
Update the drivers
Remove unwanted programs
For an instant fix use system utility tool PCFresher.
PCfressher CAN not repair, real damages, that SMART reports, ever,
sorry to break your bubble of magic.
the answer is at HP, 100s of times answered
and on fixya, most answer wrong. go figure
why not ask the real HP errors, and meanings.
https://h30434.www3.hp.com/t5/Notebook-H...
500 discussion now
https://h30434.www3.hp.com/t5/forums/sea...
