Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher Logo
Posted on Aug 19, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dishwasher smoking Started cycle, everything seemed fine. Opened it to put something in and when I closed it to restart it sounded strange. Then the smoke starting pouring out of it and it smelled like something electrical burning. I immediately turned the wall switch off. It is a Kenmore, not sure of the model at this time. Is this a common occurence like if a specific part went out? Thanks for your time.
Bill Boyd
Level 3:
Top Expert:
  • Frigidaire Master 53,816 Answers
  • Posted on Aug 19, 2017
Bill Boyd
Frigidaire Master
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11948915
Points
172802
Nothing specific until you get a technician to properly diagnose the fault
5 Related Answers
Carmen Mikulic
  • 415 Answers
  • Posted on Sep 13, 2008
SOURCE: frigidare dishwasher
can you give me the exact model # on your dishwasher and i will check for you.
Anonymous
  • 3 Answers
  • Posted on Oct 29, 2008
SOURCE: frigidaire ultra quiet I dishwasher
Sounds like the water may not be turned on to the dish washer.
The arm spins with water pressure
nick turner
  • 18 Answers
  • Posted on Jan 04, 2009
SOURCE: dishwasher had a burning smell and smoke was coming out
If the smoke was coming from inside the dishwasher... A common problem is a plastic item , utensil etc has fallen down onto the heating element. During the drying cycle this could possibly melt the plastic and generate some smoke.
woobie dog
woobie dog
  • 1273 Answers
  • Posted on Aug 03, 2009
SOURCE: My dishwasher, model # fdb1050reb1, will not start
You may have already, but try opening and closing the door and restarting the machine again. If the door switch is loose, you may be able to get it to make the connection and run. If it just palain won't work that way for you, you'll have to try to tighten up the connections on the switch, or replace it.
Best regards, --W/D--
Anonymous
  • 103 Answers
  • Posted on Nov 12, 2009
SOURCE: Frigidaire Gallery dishwasher smoke coming out of
You need to replace the blower assembly, common prob after a few years of use.
Part number: 154226802 "Blower-Crossflow", suggested list at this time is around 30.00 us dollars.
To replace: TURN OFF BRAKER TO DISHWASHER
Open door, remove inside screws form panel and carefully remove panel up from door, blower is next to timer on control panel.
I have a Baumatic BDI631 integrated dishwasher which has started making a strange noise when the water is coming out. It is washing fine but makes a buzzing noise when discharging the water which soun
It sounds like something's trapped in the pump touching the impeller. Drain the machine, isolate the electrics and see if you can access the pump, you may find a piece of debris or small article in the pipework.
1helpful
2answers
Bosch dishwasher beeping during cycle
Take the front kick panel off and see if anything under the machine is wet.
MAKING A STRANGE NOISE WHEN STARTING THE HOT START
try re-setting it. unplug power. visually see if d/w looks clean. re-connect and run an empty short cycle ensuring door properly closed. good luck
Door is locked, cannot close the door or power on
Hello Stephanie Shcherban - Try resetting the unit by unplugging it for flipping the household circuit breaker off. Wait approximately ten minutes. Restart unit and first confirm that the "child lock" option is not selected. However, if it proves to be ineffective and from what you have a described it sounds like the unit has a defective door lock switch, which will need replacing. Contact a professional to move forward accurately.
I opened the door at the beginning of the cycle to move something and then the dishwasher wouldn't start again.It still won't start and we can't get the water to drain either.
If the dishwasher was working fine before you opened it to move something, and now it does absolutely nothing, then I would suppose it is a door switch issue. The door switch is located at the top middle of control panel, and is there are a safety device to keep dishwasher from running with door opened. You need to play around with closing the door and pushing the top in various ways to see if you can get it started. However it is more than likely a faulty switch.
2answers
Dishwasher was opened to add dish and would not start back
give it a few minutes it may have a built in delay when cycle is interuptede
Jun 01, 2009 • Dishwashers
3helpful
2answers
Open the dishwaser while still filling now keeps going to error
After reading a few of the other Haier models troubles, I pulled the unit out and tip it at 45 degrees backwards for around minute. Water pored from the back of the unit, once cleaned water up reinstalled unit and all seems to be back in working order.
15helpful
3answers
Kitchenaid dishwasher KUDS02SRSS2 start light blinking won't start
I have this same kitchenaid model. It would not start after selecting the wash cycle and pressing start. The light would blink as if the door was open. I did the reset by pushing the sani-rinse, heat dry, sani-rinse, heat-dry and closing the door. You can hear something going on inside. After that stopped (about 3 minutes). I was able to select the wash cycle, press the start, close the door, and it started. Good luck!
Feb 22, 2008 • Dishwashers
After water turns on, nothing else happens
If you are hearing a humm noise after it stops filling, your motor is locked up.
Jan 04, 2008 • Dishwashers
9helpful
4answers
Diswasher motor making noise during wash cycle
It could be the impeller on the motor. The impeller fits over the shaft of the motor and might have split/broken up. That funny noise is probably the shaft spinning inside the damage impeller. Fortunately the impeler is fairly inexpensive and easy to replace. I believe there are one or two parts/covers to remove that are held in by a roughly half dozen torx screws.
Top Frigidaire Dishwashers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
