Car stalled at light and hasn't started since
Are there any codes . it sounds like your ingition coils are bad
hav not checked for codes yet. Car belongs to daugter and husband is out of town. He is thinking timing chain
make it could have jump timing. you say it back fires . that would be out of timing and or not spark to the coil
my link to my garage I am on facebookhttps://www.facebook.com/TedsRepairs
thanks..if it did jump time what other, if any damage could have been done to the motor? miles are high
really not damage. but thinking it out I do not think it jumped timing I think ignition coil or spark sound to be getting no spark. how many miles and when was the lasttune up
155K, maybe two years on tune up...pcv had to be replaced last year
that is low miles trust me. wow that long on the tune up. I bet the spark plugs are junk in that motor. the spark plugs are good for a year if that.
But even if the plugs were bad, the car was running decent and just died.
somethings but when spark plugs are bad it stresses the coil for they fight to spark. you do say it back fires
yes it backfires with and without starting fluid.
that is saying there is not spark . you could have a bad crank position sensor . that keeps the timing in place.
check for codes I bet you have a bad crank position sensor .that sensoe runs the timing
thanks. we are gonna try to pull codes Friday and proceed from there.
you can get me on facebook if you want . I have a lot of people from that do,and they are my page. I am here to hel out
Thanks and have a good night.
you are very welcome,and I am happy to help you
CAR NO START PROBLEMS:----- It
can be the issue with weak battery or faulty battery or if battery is ok,then
its faulty starter causing the issue. From
start to end troubleshooting these problem i suggest you to click the link
below and follow its procedure:----- What to Do When Car Turns Over But
Won't Start? http://technoanswers.blogspot.com/2012/11/what-to-do-when-car-turns-over-but-wont.html ----------- ------------- http://technoanswers.blogspot.in/2012/02/car-starting-issues.html ------------ http://whoisbyme.blogspot.in/2012/06/car-starting-problems.html -------- http://whatisbyme.blogspot.in/2012/05/1991-toyota-trecel-engine-starts-fine.html ---------- http://howtobyme.blogspot.in/2012/05/1994-toyota-pickup-starts-fine-but-dies.html --------- http://whatisbyme.blogspot.in/2012/06/1999-chrysler-cirrus-8-ign-fuel-starter.html ----------- http://whatisbyme.blogspot.in/2012/05/2001-toyota-camry-no-start-after.html ---------- -------------- -------- http://whatisbyme.blogspot.in/2012/05/1995-lexus-ls400-running-hot.html ---------- --------- http://www.howtorepairguide.com --------- These will help. Thanks.
Feels like backfire from engine when
decelerating?
http://schematicsdiagram.blogspot.in/2012/02/feels-like-backfire-from-engine-when.html
Jeep Backfires?
http://technoanswers.blogspot.in/2012/02/jeep-backfires.html
Nissan Pathfinder Backfires?
http://technoanswers.blogspot.in/2012/02/nissan-pathfinder-backfires.html
------------Car starting issues?
Car Starting Problems
1991 Toyota Trecel: Engine Starts fine but
dies when gets Warm?
1994 Toyota Pickup: Starts fine but dies in
few seconds?
1999 Chrysler Cirrus: 8 IGN Fuel Starter Fuse
Blows?
2001 Toyota Camry: No start After replacing Battery?
1989 Toyota Pickup Truck: Turns over but not
start?
http://whatisbyme.blogspot.in/2012/05/1989-toyota-pickup-truck-turns-over-but.html
Car dead and will not Start?
http://whatisbyme.blogspot.in/2012/05/car-dead-and-will-not-start.html
1995 Lexus LS400: Running Hot?
2001 Toyota Prius will not start?
http://whatisbyme.blogspot.in/2012/05/2001-toyota-prius-will-not-start.html
1996 Jeep Grand Cherokee: Engine will not start?
http://repairhelpcenter.blogspot.in/2012/06/1996-jeep-grand-cherokee-engine-will.html
Mitsubishi will not start
SOURCE: 2003 Mazda 6 leak
i would try an easy fix for this problem, change your PCV if its burning oil like that! also checkout 6crew.com, im "ed4ward1982"
SOURCE: First: alarm went off on its own.(mazda 6 2003).
there is often a small back up battery in the immobiliser unit itself, if you can locate this unit and replace the battery with the ignition on / engine running, then it should not need recoding and work fine after that. The other thing that could be wrong is the key battery (if the fob has one) or the transponder chip in the key head. If the key signal is low the immobiliser lamp will light during driving, but this does not explain the alarm going off. That is more likely either a poor vehicle battery, alarm / immobiliser back up battery, or another electrical fault such as water leakage into a tail-light or even the alarm unit itself when it rains. A lot of alarms are voltage sensing and when the vehicle is parked they will alarm if the battery voltage changes for any reason, though not during driving so the battery in the immob is my first choice to look at.
SOURCE: 2003 Mazda Tribute will start, idle rough for a
check the fuel filter air filter and vacuume lines if they all good make sure the spark plugs are making a bright blue spark
