The Caprice would not take overdrive, so I replaced the whole transmission. (700 R4) and it still will not take overdrive. Its full of fluid. If I do need a shifter kit, can someone give me the details, Why, where to find one, how much? and how? Thank you
Check the help link mentioned below:---- Also
i suggest you to refer these gear shift issues, which are mostly noticed. These
are direct links with appropriate solutions to
the specific problems of gear ****. GEAR SHIFT ISSUES http://howtobyme.blogspot.com/2011/11/chrysler-pt-cruiser-only-goes-in-first.html ---------- Car is stuck in park and the shift will not move? http://howtobyme.blogspot.com/2011/08/car-is-stuck-in-park-and-shift-will-not.html http://howtobyme.blogspot.com/2011/11/car-will-not-come-out-of-park.html http://howtobyme.blogspot.com/2011/11/automatic-transmission-will-not-go-into.html ---------- http://schematicsdiagram.blogspot.com/2011/12/car-wont-downshift-sometimes.html http://schematicsdiagram.blogspot.com/2011/12/buick-park-avenuetransmission-will.html http://schematicsdiagram.blogspot.com/2011/12/car-transmission-will-no-go-into-park.html http://schematicsdiagram.blogspot.com/2011/12/shift-indicator-directly-goes-to-2nd.html http://schematicsdiagram.blogspot.com/2012/01/third-gear-missing-and-engine-losing.html http://technoanswers.blogspot.com/2012/01/chevrolet-silverado-has-whining-sound.html http://technoanswers.blogspot.com/2012/01/hard-to-shift-gears-on-manual.html http://technoanswers.blogspot.com/2012/01/car-hard-shift-at-slow-speeds.html http://technoanswers.blogspot.com/2012/01/automatic-transmission-shift-lever-hard.html http://schematicsdiagram.blogspot.in/2012/02/2000-nissan-maxima-shifts-hard.html ------- http://schematicsdiagram.blogspot.in/2012/03/vehicle-noticed-sluggish-delayed-shifts.html ------- http://schematicsdiagram.blogspot.in/2012/06/2007-hyundai-santa-fe-will-not-shift.html These details will help. Thanks.Overdrive light in the dash blinks?
http://repairhelpcenter.blogspot.com/2012/01/overdrive-light-in-dash-blinks.html
--------OD light flashing and transmission fluid leaking?
http://repairhelpcenter.blogspot.in/2012/02/od-light-flashing-and-transmission.html
Gear
indicator Shows "3" Instead Of "D"?
http://whoisbyme.blogspot.in/2012/07/gear-indicator-shows-3-instead-of-d.html
2006 Chrysler 300c: Shifter Stuck in Park?
http://technoanswers.blogspot.in/2012/06/2006-chrysler-300c-shifter-stuck-in.html
1998 Ford Expedition: Will not Shift Out of
Park?
http://schematicsdiagram.blogspot.in/2012/06/1998-ford-expedition-will-not-shift-out.html
Car will not move when in gear?
http://repairhelpcenter.blogspot.in/2012/02/car-will-not-move-when-in-gear.html
Mercedes-Benz transmission sticks in first gear?
http://technoanswers.blogspot.com/2012/01/mercedes-benz-transmission-sticks-in.html
Mercedes Benz not engaging in first gear?
http://technoanswers.blogspot.com/2012/01/mercedes-benz-not-engaging-in-first.html
Chrysler PT Cruiser only goes in First gear?
2007 Ford Expedition: How to shift car in neutral with Dead Battery
http://www.howtorepairguide.com/2012/11/2007-ford-expedition-how-to-shift-car.html
2002 Nissan sentra will not go out of park mode?
http://technoanswers.blogspot.in/2012/02/2002-nissan-sentra-will-not-go-out-of.html
Nissan Sentra stuck in park?
http://technoanswers.blogspot.in/2012/02/nissan-sentra-stuck-in-park.html
Car will not come out of Park?
Automatic transmission will not go into high
gear?
Car won't downshift sometimes?
Buick Park Avenue: Transmission will
Not shift into drive?
No
First gear Starts In Second Gear
http://www.howtobyme.blogspot.com/2012/07/no-first-gear-starts-in-second-gear.html
Ford Taurus won't shift from park?
http://schematicsdiagram.blogspot.com/2011/12/ford-taurus-wont-shift-from-park.html
2006 Ford F150: Will Not Shift out Of Park?
http://technoanswers.blogspot.in/2012/06/2006-ford-f150-will-not-shift-out-of.html
Car Transmission will not go into Park mode?
1998 Chrysler Voyager: Transmission Problem?
http://howtobyme.blogspot.in/2012/06/1998-chrysler-voyager-transmission.html
Shift indicator directly goes to 2nd when key
is turned ON?
Third gear missing and engine losing power?
Chevrolet silverado has whining sound in gear?
2002 Chevrolet Avalanche Z71: Gear shift
Issue?
http://whoisbyme.blogspot.in/2012/06/2002-chevrolet-avalanche-z71-gear-shift.html
Hard to shift gears on Manual transmission?
Car hard shift at slow speeds?
Transmission-Hard To Down Shift
http://technoanswers.blogspot.in/2012/07/transmission-hard-to-down-shift.html
Automatic transmission shift lever hard to move on cold
mornings?
2000 Nissan maxima shifts hard?
Vehicle noticed sluggish delayed shifts while
driving?
2007 Hyundai Santa Fe: Will not Shift out of
Park Mode?
SOURCE: Transmission problems with a 2002 Chevrolet Silverado 4X4.
Fastboyz is on track with his answer.there are quite a few updates on your transmission for shift concerns. this is done with a tech2 scanner and reprograms computer. also if you have installed larger tires this will need to be updated. can cause problem also.Just because there is no trouble code does not mean it is not a computer related problem. have it checked for updates
SOURCE: 2002 Ford F150 5.4L hard shifting
Have you ever changed the transmission fluid flush and replaced the transmission filter?
SOURCE: f150 transmission neutralizes when shifts to overdrive
I have that exact same truck and transmission and My Transmission did the exact same thing about a year ago and there was some kind of snap ring inside the transmission that broke. I originally thought it had to be an electirical problem because the truck shifted fine until OD or if i turned OD off. The 4r70w is a light transmission and i would suggest you have a shift kit put in and they make a heavier kit to beef it up.. Sorry its probably not the new you were looking for.
SOURCE: transmission shifts ony 123 no overdrive, it slip in overdrive
sorry to say this trans has to be removed and rebuilt seems like od clutches burnt out-do you tow heavy trailer with truck as you have to tow with od off(push button on shifter)
SOURCE: transmission will not shift into overdrive
Overdrive is electrically controlled by the pcm. When it's cold you need to check to see if the pcm is grounding the overdrive solenoid. If it is the solenoid might be bad or if the pcm is not grounding it then you need to check items that would cause the pcm to lock out overdrive. Coolant temp, TPS, Vehicle speed sensor, ECT. You will have to have it scanned to do this.
