2005 Kia Sedona Logo
Scott Cassinelli Posted on Nov 28, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where is # 2 cylinder located on 2005 kia sedona
Thomas Perkins
Level 3:
  • Kia Master 15,088 Answers
  • Posted on Nov 28, 2012
Thomas Perkins
Kia Master
Level 3:
Answers
15088
Questions
0
Helped
3383888
Points
54869
Here's a link to the cylinder location.
  • Scott Cassinelli Nov 28, 2012
    Thank you so much, have a great night.
raj somaiya
Level 3:
  • Kia Master 5,370 Answers
raj somaiya
Kia Master
Level 3:
Answers
5370
Questions
0
Helped
3568163
Points
14579
Click the link below and view exact cylinder diagram the order is ascending 1-2-3-4-5-6.
2005 KIA Sedona Ignition coil Cylinders
http://technoanswers.blogspot.com/2012/11/2005-kia-sedona-ignition-coil-cylinders.html
----------These will help.Thanks.
Testimonial: "Thank you. It was a spark plug and the coil on top"
Ronnie Smith
Level 2:
Habit-Forming:
  • Kia Expert 77 Answers
  • Posted on Apr 23, 2015
Ronnie Smith
Kia Expert
Level 2:
Habit-Forming:
Answers
77
Questions
0
Helped
63380
Points
306
I hope this diagram helps.
where is # 2 cylinder located on 2005 kia sedona - 2-cylinder-located-2005-kia-sedona-ir03o0ur3ff3pxc4zrfsqvc4-3-0.jpg
5 Related Answers
emissionwiz
Marvin
  • 85242 Answers
  • Posted on Jun 19, 2009
SOURCE: i have codes po430 and p2422 kia sedona
P0430 Catalyst System Efficiency Below Threshold (Bank 2)
P2422 Evaporative Emission System Vent Valve Stuck Closed
Roger Foster
  • 701 Answers
  • Posted on Oct 19, 2009
SOURCE: where is the crank position sensor located in 2005
Hello martinezmelm: My name is Roger and I can answer your question. To locate the crankshaft position sensor. You will need to remove the timing cover. You will find the sensor on top of the crankshaft gear. Between the V of the timing belt.
Should you need further help please just ask. Please rate the answer as this way I know it was helpful. Thank You for using Fix Ya. Roger
Anonymous
  • 396 Answers
  • Posted on Nov 05, 2009
SOURCE: help me to locate the fuel filter and fuel pump in the kia sedona
start of at the gas tank look under neath there are some black lines running towards the engine follow it to a small gold color that ataches to the line you are following that is the filter the pump is in the gas tank you need to drop the straps at the tank to bring it down
Anonymous
  • 2317 Answers
  • Posted on May 02, 2010
SOURCE: How do change the serpentine belt on a 2005 Kia
There is a tensioner pulley that has a nut in the middle of it, loosen that nut and there is a tensioner bolt that when you loosen it, it slides the pulley away from the belt to replace it.
Anonymous
  • 2382 Answers
  • Posted on Mar 16, 2011
SOURCE: where is the crankshaft position/crank
Hi, at the front of the crankshaft. if its near time for the timing belt, you want to replace it along with any pullies, tensioner and water pump
The crankshaft position sensor is mounted on the engine near the crankshaft.
Operation
The crankshaft position sensor is a Hall-Effect sensor that senses the crank angle (piston position) of each cylinder and converts it into a pulse signal. The signal from the sensor is relayed to the ECM to indicate engine rpm and the position of the crankshaft.
Removal & Installation
  1. Disconnect the negative battery cable.
  2. Disconnect the connector from the sensor.
  3. Remove the bolt that retains the sensor in place.
  4. Remove the sensor from its mounting. To install:
    1. Installation is the reverse of the removal procedure.
    2. Clearance between the sensor and the sensor wheel should be 0.020-0.059 inch. 2002-2005
      1. Properly connect the scan tool.
      2. Start the engine and allow it to idle.
      3. Be sure the idle position switch is ON.
      4. Specifications are as follows:
        Temperature - 4°F, test specification 1500-1700 RPM Temperature 32°F, test specification 1350-1550 RPM Temperature 68°F, test specification 1200-1400 RPMTemperature 104°F, test specification 1000-1200 RPM Temperature 176°F, test specification 650-850 RPM
2005 Kia Sedona 2EX 3.5. Where is the fuel control module please?
Question edited for clarity.
Question moved to sub category.
P0304 is only a misfire error to cylinder 4.
https://www.700r4transmissionhq.com/p0304-kia-sedona/
There isn't a 'fuel control module'.
https://www.google.com/search?q=2005+Kia+Sedona+2EX+3.5+Fuel+control+module
But there is a fuel pressure regulator
https://www.google.com/search?q=2005+kia+sedona+fuel+pressure+regulator+location
When you look up fuel 'module', you come back to the fuel pump.
https://www.google.com/search?q=2005+kia+sedona+fuel+module+location
One thing you might try is moving coil pack 4 to another cylinder and see if the code moves. After that do a plug swap and see if it moves. Do them separately not coil and plug together..
Where is the cooling system bleed valve located 2005 kia sedona
are you referring to the drain plug? if so, it is located on the passenger side bottom facing the front bumper. see attached diagram under radiator removal. http://www.kia-forums.com/attachments/kia-carnival-sedona/9678d1319024147-removing-radiator-kia-sedona-2005-remove-radiator.jpg
Location of bank 2 sensor 1 on a kia Sedona 2005 lx
left side of exaust after catalictic converter
Where is the starter located
Hi, the Kia Sedona starter (and all other major parts) are the same from 2000 to 2005. Here is a link with your starter location and how to remove it:
http://www.kia-forums.com/kia-carnival-sedona/84617-starter-problem-sedona-2003-help.html
In this pic you can see the starter's location (hidden behind the exhaust heat shield):79720193-778a-42e2-b4ff-a2d753f3adce.jpg
1helpful
Where is cylinder 2 located on a 2005 kia sedona?
Kia Sedona 3.5 liter DOHC V-6 (click image fo zoom)
Hope helps (remember to rate this answer)
16helpful
2answers
I NEED A FIRING ORDER DIAGRAM FOR A 3.5 KIA SEDONA I HAVE TROUBLE CODES 302 AND 306 AFTER COILS,PLUGS AND WIRES WERE REPLACED
Firing order 1.2.3.4.5.6
Looking at engine , number 1 cyl left front,number 2 left middle,3 left back
Number 4 right front,5 middle right ,6 back right
Fault codes indicate missfire cylinder 2 and 6
3helpful
3answers
2005 kia sedona ECU replacement
2005 kia sedona ecu is located on passenger floor under carpet. After you remove the carpet half way, there is a silver plate you have to remove with 10mm deep well socket. there are 4 connector plugs.
Top Kia Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ZJ Limited
ZJ Limited
Are you a Kia Expert? Answer questions, earn points and help others
