Question about HP Compaq ProLiant DL580 G4 (430811001) Server
What version of Linux runs on DL580 G4?
Installed RH 5, server boots to screen displaying OS info and hangs.
    New Friend:
  • 4 Answers
SLES 10 = SUSE LINUX Enterprise Server 10 this system is built to run efficiently with it.
Posted on Jun 07, 2017
    New Friend:
    Problem Solver:
  • 9 Answers
Debian
Posted on Jan 01, 2015
  • HP Master
  • 2,072 Answers
Minimum Supported Red Hat Updates •Red Hat Enterprise Linux 5 Update 1 •Red Hat Enterprise Linux 4 Update 5 6-Core/4-Core Intel Xeon Processor 7400 Series •Red Hat Enterprise Linux 5.22 •Red Hat Enterprise Linux 4.7 Minimum Supported Novell Service Packs•SUSE LINUX Enterprise Server 10 SP1•SUSE LINUX Enterprise Server 9 SP31 6-Core/4-Core Intel Xeon Processor 7400 Series •SUSE LINUX Enterprise Server 10 SP23 •SUSE LINUX Enterprise Server 9 SP44
Posted on Dec 03, 2012
SOURCE:
  • 39 Answers
SOURCE: Proliant DL380 G4 server occasionally rebootes.
Try to update the firmwares. Maybe the threeshould of the fans are incorrect. A new firmware can correct this problem.
Let me know if this post helps
Posted on Dec 17, 2007
  • 340 Answers
SOURCE: Problem with DL380 G4 after reboot
do you use software/hardware raid?
hopefully hardware :-)
and is it mirrord or raid5?
Posted on Jan 28, 2008
micromaster
  • 3614 Answers
SOURCE: ugrade of DL380 G4 Server HDD Raid Array 36GB --->146GB Required
Try to look at this Guide & Manual on "HOW TO"
Just let me know..
Hope my initial idea/info helps you..
Thanks,
micro
Posted on Jul 25, 2008
  • 152 Answers
SOURCE: i am using HP DL380 G4 SERVER,cd rom drive is not
Make sure the BIOS is fully updated from the HP website. Most DL3-series servers supported booting from an external USB cd, try F10 or F12 at boot in order to bring up a boot menu.
Posted on Oct 21, 2009
  • 8 Answers
SOURCE: Hp compaq prolaint dl380 g4
Even with out the display, can you ping it from the network? If not I would power off the server. Unplug the power. Take the cover off the server, reseat the memory. Pullout the both power supplies and reseat them. remove any cards in the server except the disk controller. Reseat all the disk drives, make sure you put them in the same slot you pulled them from, even though it doesnt matter. Plug back in and see if you get a display. You can move the memory around also or take out some. If you are not getting an intermittent beep or a red display on the front panel, your system board may be shot.
Posted on Jun 25, 2010
I have a Proliant HP DL580 G4 that had its system board replaced. The OS (Windows 2003 Enterprise) now only recognizes one cpu core. The server has 4 dual core cpu's. How can I get the OS to see all 8...
You may need to check your BIOS to make sure the multiple CPU function is enabled. Once it is, a reboot should correct this for you.
Good Luck
C2Solutions
Sep 08, 2011 | HP Compaq ProLiant DL580 G4 (430811001)...
Proliant server running Linux hangs at "attempting
I'd say the hard disk went bad. See if it'll boot from a live cd to copy your data off of the linux drive (if it's accessible at all).
Dec 30, 2010 | HP ProLiant ML370 G4 Server
Hp DL 380 G4 no display on screen, all the status lights are green
We had the same problem with a G5 version of the dl380, no video at boot or OS boot. This model fortunately had another video out on the front panel that worked. However, I believe that the G4 does not have that option coupled with using the Rage XL's from ATI for video. Have you tried installing another video card into the expansion slots for video? If you are able to, you may find that when you run your smartstart and load/reload the OS your video will work with the onboard.
Dec 03, 2009 | HP Compaq ProLiant DL380 G4 Server
Redhat es5
This model was found not to be 64bit but 32bit.
May 18, 2008 | HP Compaq ProLiant DL380 G4 Server
How do I enable 64 bit processing on a HP Compaq Proliant DL580 G4
I don't think that you "enable" 64 bit processing, you buy a server with a 64 bit processor. Intel's Itanium is such one. You then install Windows Server 2003 x64 version.
That's pretty much it I think.
Jan 15, 2008 | HP Compaq ProLiant DL580 G4 (430811001)...
HP Compaq ProLiant DL580 G4 (430811001) Server Logo
413 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
