New battery worked for awhile. Bsttery fully charged.alternator not drainng battery. But car has to be jumped to start.
Maybe not a full time drain,sometimes alternators will work off and on...have it checked under load,at a shop.
SOURCE: 1999 ford escort zx2 alternator works brand new battery but battery isnt charging !
you will have to check the voltage whith the engine running .should be 13.6 or better
Stecorbett:
May I suggest that you drive your car to one of the major auto stores and they can and will check your alternator for you to make sure it is good/bad.These places like AutoZone do this all the time. They do not charge for the check out. (Of course they are hoping that if you need a part you will buy it from them.
One other suggestion. If you do need a new alternator, get a rebuilt one. It is cheaper and most always comes with a warranty.
Hope this helps Good luck Loringh PS please take a moment to give me a rating
SOURCE: New Car Battery on '97 Ford Mustang - car has no juice, will not start.
Main fuse or fusible link blown? What led to the need for replacement batteryand jump any symptoms?
SOURCE: 2002 Kia Sedona new battery & alternator car dies while driving
hey buddy the same that happeanto me, its your alternator dont make any one give you the run a around alternator for sure. i got my alternator from gb500 it cost about $160.00 after tax.
SOURCE: NEW ALTERNATOR, NEW BATTERY, CAR still dies and wont start
Check the main power fuse that goes to the alternator output. if the alternator went out it could have burnt this fuse also.
