The unit stopped working and will not react to any touch pad comand. Sometimes it will start up on its own but now heat. Unit did start wroking when left alone for awhile but now has stopped again.
SOURCE: Kitchen aid microwave oven not working.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
I'd say you have a contaminated or failing keypad or possibly residue on the boar dor where the keypad connects to the board.
Is it possible that some spray cleaner got into the controls?
I always recommend that users instead spray cleaner on a soft cloth then wipe the control panel.
Also, I always recommend non-ammonia cleaners since ammonia can crack and damage plastic.
Otherwise, the spray can get into the controls and lock it up or make it act odd.
If it does not dry out over time, it may need to be manually dried or blown out.
The keypad may be damaged or worn out, or control unit may be damaged.
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: Kitchenaid KHMS155LSS 1000 watt microwave makes grinding noise
Chances are you have a bad stirrer motor or the stirrer blade is jamming or loose on the motor shaft.
Your owner's manual should tell you how to remove the stirrer cover to check it.
If
for some reason you don't have your owner's manual, you can download it free here, as well as the parts manual for your model.
You can also find
model number here.
We're
happy to help you with free advice and we'd appreciate your
SOURCE: Microwave stopped heating, evenything else works
SOURCE: kitchenaid microwave model KBMC140HSS03 will not
Your membrane keypad is shorting.
It comes as an assembly, so it's pretty easy to replace yourself. It is part number 4453420 and you can get it here for $235.33 plus shipping.
You can also find helpful exploded views at that link.
The picture below shows you how to unlock a typical membrane keypad connector.
We're
SOURCE: my Kitchenaid Superba kaw38avm726 microwave does not heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
dhjjd
