Question about HP Compaq nc2400 Notebook
Its plug in but battery wont charge
My HP Compaq nc2400 laptop wont charge at all but when i plug it in it cuts on but when i plug it in the battery light (on the front of the laptop) glow green then it turn yellow an then i cuts off and it wont charge on do anything till i press the power button anyone here to help me?
    Novelist:
    Champion:
  • 233 Answers
If your battery will not charge, you need to run a test on some components on the laptop. The battery, the charger and the laptop itself. Once you detect the faulty conponent then you replace it with a new one.
To test the battery:
1.Power off the laptop,
2.Take out the battery,
3.Insert it in another laptop,
4.Check of it will charge,
If the battery holds a charge there, then it means the problem is not from the battery, but if it does not hold a charge, then it means the battery is defective and need to be replaced with a new one.
To test the charger:
1.Unplug the charger from the present laptop,
2.Connect it to another laptop to see if it will charge.
If it charges the laptop, then it means the charger is alright, and if it does not charge the laptop, then it means the charger is bad and need to be replaced.
To test the laptop:
1.Turn off the laptop,
2.Disconnect your present charger,
3.Remove your present battery pack,
4.Insert a well tested battery into the laptop,
5.Connect a well tested charger to the laptop.
If it powers on, then it and charges, then it means the laptop is working fine, but if it does not charge, then it means the connection port of the laptop is bad.Hope this information was helpful.
Posted on Nov 30, 2012
SOURCE:
AvioriX
  • 689 Answers
SOURCE: compaq - will not turn on - plugged in?
Disconnect the AC adaptor, Take the battery out and press and hold the power button about 5 seconds. After that connect the AC adaptor and insert the battery turn it on. If issue persist please inform for further troubleshooting.
Good Luck
Posted on Mar 01, 2008
  • 8 Answers
SOURCE: hp compaq nx9110 runs only on battery when it is plugged to AC
It sounds like you have a faulty power jack, and possibly a dead battery as well. You should take it to a person you may know that can order and solder a new one in or take it to your local electronics repair shop. I do repairs like this on a daily basis for my computer business.
Posted on Apr 28, 2009
  • 59 Answers
SOURCE: Problem HP Compaq nx 7300 Yelllow light 8x
Have you had previous problems with your laptop power supply and battery? I have this same laptop and use it very regularly. I do have problems with battery life, but never actually powering on. I suspect the battery is not accepting a charge. My suggestion is to replace the battery and see how things go.
Posted on Oct 20, 2009
Testimonial: "I repclaced the charger...no is ok again...thx for the help :-)"
  • 37 Answers
SOURCE: hp compaq nx6310 wont turn on. When pressing power
it will either be the batery is no good, or adapter ot the port on your laptop
Posted on Feb 27, 2010
  • 231 Answers
SOURCE: My roommate's HP G60 laptop will not turn on.
you have a bad powercord or power supply
Posted on Apr 13, 2010
How do i replace a cmos battery in my hp compaq nc2400
I was unable to locate your specific laptop this might ge you some in sight in what to look for and how to remove cmos battery remember some cmos batteries are soldered in
RTC battery replacement procedure on Compaq HP Mini 110 netbook & clear CMOS http://www.youtube.com/watch?v=P_cxAireIsw
Feb 26, 2013 | HP Compaq nc2400 Notebook
Compaq nc2400 no video
nc2400. (circa , 2007 made) and still supported at HP (we arent HP)
another old., pc dead. value is $20 (see ebay solds? yes)
so it less dead like this.
here are the steps,
main battery out, ? work now,
that is correct, BIOS works , with no battery, AC PACK good, 19vdc = good.
and hdd out , cd out.
ever heard OF CCFL ?
2010 then ended, so I first check this , yours being 2007
BINGO CCFLs, they are short lived lamps back lamps.
so use a flash light.
btw the externa VGA jack needs Fn+F4 pressed to work!!!
per manual below.
your SM is here
http://h10032.www1.hp.com/ctg/Manual/c02012281
now the test, acid test on CCFL.
with bios hot keys hammered, per book above.
then the magic flash light trick, (posted here now 300 times)
look ma, no blacklight.. but gee see the data., BINGO.
http://www.pcdied.com/monitors.html#flashlighttest
Sep 28, 2017 | HP Compaq nc2400 Notebook
Compaq Presario CQ61-320SA Notebook PC
contact hp tech support and give them the serial no and product no of the notebook...battery connectors have gone bad
Jan 29, 2012 | Compaq Presario CQ61-310US Laptop
I have an hp compaq 6720s and my charge port light blinks rapidly, it wont let me charge my battery and the computer wont turn on when the battery is full any thoughts?
Usually a rapid blinking charge light is alerting you of a battery fault. Try taking the battery out, plugging your computer in, and turning it on (with the battery out). If it boots up, then your battery is to blame, call customer service right away and see about getting a new battery.
Mar 24, 2011 | HP Compaq 6720s Notebook
My compaq Evo n610c my battery wont charge when on ac power.The light for when the battery wont go on.
sounds like your DC coonector came loose from the system board.it is a common problem with laptops,
Problem symptoms:
  1. Laptop randomly shuts down without any warning.
  2. Power LED and battery charge LED start flickering when you wiggle the power cord or the AC adapter tip on the back or your laptop.
  3. The battery will not get charged.
  4. When you plug AC adapter, the laptop appears to be dead and there is no LED activity at all (DC-IN jack on the system board is broken).
here is how to repair:
http://www.laptoprepair101.com/laptop/2007/12/06/dc-power-jack-repair-guide/
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 26, 2010 | HP Compaq Evo n610c Notebook
Laptop battery wont charge?
It could be the battery needs replacing ... it shows that the battery is charging but it doesn't keep the charge .....
May 23, 2009 | Compaq Presario 700 470024-192 Notebook
Battery wont work
The battery is dead and it won't charge or hold its charge (all rechargeable batteries have a finite number of charge and discharge cycles). You need to buy a new battery, or just use the laptop connected to the mains supply.
Oct 29, 2008 | HP Compaq Evo Notebook N600c
Open Questions:
See all HP Compaq nc2400 Notebook Questions
HP Compaq nc2400 Notebook Logo
343 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
