The
shifter needs to be inspected. The shifter assembly is got misaligned, it has
to be open and realign. There
are many other possibilities. But if it was working right up till now and
suddenly this occurred then its shifter
assembly alignment issue. Also
i suggest you to refer these gear shift issues, which are mostly noticed. These
are direct links with appropriate solutions to
the specific problems of gear ****. GEAR SHIFT ISSUES http://howtobyme.blogspot.com/2011/11/chrysler-pt-cruiser-only-goes-in-first.html ---------- Car is stuck in park and the shift will not move? http://howtobyme.blogspot.com/2011/08/car-is-stuck-in-park-and-shift-will-not.html http://howtobyme.blogspot.com/2011/11/car-will-not-come-out-of-park.html http://howtobyme.blogspot.com/2011/11/automatic-transmission-will-not-go-into.html ---------- http://schematicsdiagram.blogspot.com/2011/12/car-wont-downshift-sometimes.html http://schematicsdiagram.blogspot.com/2011/12/buick-park-avenuetransmission-will.html http://schematicsdiagram.blogspot.com/2011/12/car-transmission-will-no-go-into-park.html http://schematicsdiagram.blogspot.com/2011/12/shift-indicator-directly-goes-to-2nd.html http://schematicsdiagram.blogspot.com/2012/01/third-gear-missing-and-engine-losing.html http://technoanswers.blogspot.com/2012/01/chevrolet-silverado-has-whining-sound.html http://technoanswers.blogspot.com/2012/01/hard-to-shift-gears-on-manual.html http://technoanswers.blogspot.com/2012/01/car-hard-shift-at-slow-speeds.html http://technoanswers.blogspot.com/2012/01/automatic-transmission-shift-lever-hard.html http://schematicsdiagram.blogspot.in/2012/02/2000-nissan-maxima-shifts-hard.html ------- http://schematicsdiagram.blogspot.in/2012/03/vehicle-noticed-sluggish-delayed-shifts.html ------- http://schematicsdiagram.blogspot.in/2012/06/2007-hyundai-santa-fe-will-not-shift.html These details will help. Thanks.
Gear
indicator Shows "3" Instead Of "D"?
http://whoisbyme.blogspot.in/2012/07/gear-indicator-shows-3-instead-of-d.html
2006 Chrysler 300c: Shifter Stuck in Park?
http://technoanswers.blogspot.in/2012/06/2006-chrysler-300c-shifter-stuck-in.html
1998 Ford Expedition: Will not Shift Out of
Park?
http://schematicsdiagram.blogspot.in/2012/06/1998-ford-expedition-will-not-shift-out.html
Car will not move when in gear?
http://repairhelpcenter.blogspot.in/2012/02/car-will-not-move-when-in-gear.html
Mercedes-Benz transmission sticks in first gear?
http://technoanswers.blogspot.com/2012/01/mercedes-benz-transmission-sticks-in.html
Mercedes Benz not engaging in first gear?
http://technoanswers.blogspot.com/2012/01/mercedes-benz-not-engaging-in-first.html
Chrysler PT Cruiser only goes in First gear?
2007 Ford Expedition: How to shift car in neutral with Dead Battery
http://www.howtorepairguide.com/2012/11/2007-ford-expedition-how-to-shift-car.html
2002 Nissan sentra will not go out of park mode?
http://technoanswers.blogspot.in/2012/02/2002-nissan-sentra-will-not-go-out-of.html
Nissan Sentra stuck in park?
http://technoanswers.blogspot.in/2012/02/nissan-sentra-stuck-in-park.html
Car will not come out of Park?
Automatic transmission will not go into high
gear?
Car won't downshift sometimes?
Buick Park Avenue: Transmission will
Not shift into drive?
No
First gear Starts In Second Gear
http://www.howtobyme.blogspot.com/2012/07/no-first-gear-starts-in-second-gear.html
Ford Taurus won't shift from park?
http://schematicsdiagram.blogspot.com/2011/12/ford-taurus-wont-shift-from-park.html
2006 Ford F150: Will Not Shift out Of Park?
http://technoanswers.blogspot.in/2012/06/2006-ford-f150-will-not-shift-out-of.html
Car Transmission will not go into Park mode?
1998 Chrysler Voyager: Transmission Problem?
http://howtobyme.blogspot.in/2012/06/1998-chrysler-voyager-transmission.html
Shift indicator directly goes to 2nd when key
is turned ON?
Third gear missing and engine losing power?
Chevrolet silverado has whining sound in gear?
2002 Chevrolet Avalanche Z71: Gear shift
Issue?
http://whoisbyme.blogspot.in/2012/06/2002-chevrolet-avalanche-z71-gear-shift.html
Hard to shift gears on Manual transmission?
Car hard shift at slow speeds?
Transmission-Hard To Down Shift
http://technoanswers.blogspot.in/2012/07/transmission-hard-to-down-shift.html
Automatic transmission shift lever hard to move on cold
mornings?
2000 Nissan maxima shifts hard?
Vehicle noticed sluggish delayed shifts while
driving?
2007 Hyundai Santa Fe: Will not Shift out of
Park Mode?
thanks raj for the reply i found the revers stop is stoping the lever going over to far to slectt
thanks raj ifound the revers stop is stoping the lever going over to slect 1st 2nd gear i can get the gears by lifting thr revers lock then once in gear moveing the lever backcuold this be a cable problem ?or lever problem as someone told me they can bend
