Thanks, I used your solution. My oven woks well.
I cleaned the smoke filter, took of the top cover, in front of electronics is the brown smoke sensor. I took of one wire off the sensor, started the oven (beware of not shortcutting anything) the f06 error message had disappeared. I put back the wire, mounted the top cover and the oven functions like new.
Thanks, I used your solution. My oven works well.
I cleaned the smoke sensor with electronics cleaning spray, there is an access hole inside the oven
The oven worked fine after doing this
