Have this switch in 2 separate rooms; been working great. Now all of a sudden neither one (in 2 different rooms) works. It happened once this weekend and then they worked again. Now not working. Turned them off on wall plate, then back to on... nothing. Checked the breaker box and all switches are on. I'm perplexed!
Very carefully turn the breakers off, then open the switch on the wall and see if there are loose wires, or corrosion. You can disconnect the wire from the switch and hook up an electric bulb to it with wire, then test the switch to see how the bulb acts.
Never try it without turning the breakers off. If the light works, you may want to check the fan motors to see if the have loose/broken wires. Depending on how old the fans are, they could just be wearing out. Check for brushes in th emotors if possible.
Check all connections where any power wires or ground wires are connected. Even on the switches. and yes on the fan itself. Sometimes a wire on a connection will vibrate loose and will work then not work. Make sure they are tightly put together.
SOURCE: I have a Westinghouse 77870 remote control with a light problem
read your intruc. manual and proceed according. download from www.fitness.manualsonline.com or www. retrevo.com
However you retight the spring contacts with pliers for better contacts batteries. 2) Open the re.control and clean the keypads for dirty, oxide with special spray contacts. 3) If the problem persist go to the repair shop TV for fix it.
God bless you
SOURCE: westinghouse tv remote doesn't work
1) replace new batteries with the same tipe alkaline
2) see the polarities are wrong
3) clean the contacts batteries with c. cleaner
4) retight the spring contacts batteries with l plier for better contacts
5)open the r. control clean the keypads from dirty, corrosion, oxide and bad contacts.
6) reset the code
7) try again, if the problem persist go to the repair shop TV for fix it.
God bless you
