SOURCE: KONICA MINOLTA BIZHUB C350 WITH ERROR CODE C0960
Check your bypass tray, the tray is on the right side of the machine, the tray flips out for legal and 11x17 paper sizes. Check that there is nothing jamed inside, code says that the tray can't lift. so check for anything jamed inside down there. As to reset the code open then close the front door where you put the toner. Turning the machine on and off will not reset the code. but open and closing the front door will clear about 80% of the service codes.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: i have a 3508 code on my minolta bizhub 6500
Fuser (HOT SECTION) Code requieres technical service to prevent completly destroying machine
SOURCE: Blurry print on Minolta Bizhub C350
CLEAN LASER UNIT ON THE DOOR U HAVE STICK AND PADS FOR CLEANING
SOURCE: C-0F32 FOR KONICA MINOLTA BIZHUB C350
Abnormally low toner density
detected Magenta ATDC Sensor
T/C 0.21 % or less is detected ten consecutive times
in the Developing Unit as validated through the toner
replenishing amount determination control.
Check Developer unit, check toner supply ratio in the service mode, under Image Process control and make sure that Toner motor is sping and adding toner into Dev. unit.
Also check and see if you have enough Developer. clean ATDC sensor and run Image Quality adjustment
SOURCE: cof32, blank copy on printing and copying bizhub
Have you open closed the front door to clear code? have you replaced the black image unit? Not the black toner but the image unit Black.
