Question about Maytag 24 in. MDB3700 Built-in Dishwasher
Leaking dishwasher The dishwasher leaks a stream of water at the base -bottom left corner whenever it goes into the final rinse cycle. It does not leak when it is in the wash mode. This leak just seemed to develop suddenly. There was no build up -ie a small stream of water. I just noticed a big puddle on the floor one day after dishwasher had completed its cycle
  • 5 more comments
  • Mary Keith Dec 05, 2007
    I have a Maytag model DWU8240AAX built-in and it pours water onto the floor every wash. Where can I find the vent to clean it out? Thanks.
  • STUL Jan 26, 2008
    I HAVE A MAYTAG DWU9200AAX NOT PART OF THE RECALL.. JUST NOTICED WATER POURING OUT FROM THE DOOR AREA. BEFORE READING ALL OF THE INFO ON THE WEB I BOUGHT A DOOR GASKET WILL TRY IT TOMORROW AFTER I TRY THE REST OF ALL THE ADVICE EVERYONE HAD, SOAP GASKET, WAX MOTOR O-RING, LOADING, BROKEN BOTTOM WASHER ARM. THIS IS GREAT THANKS EVERYONE FOR YOUR HELP I'LL LET YOU KNOW THE GOOD OR BAD NEWS.
    STU
  • whetsel Oct 07, 2008
    I have a mdb7100awb Dishwasher..
    My dishwasher is also leaking at the bottom on left side..It just started suddenly... It starts leaking at the start of 1st cycle..had a plumber look at it and said he thinks it is the gasket. Help..
  • stanstr Jan 18, 2009
    I have the same problem, on a Maytag DWU9921BAE. It leaks water. We stopped using it some time ago. It leaks at the end of it's cycle, leaving a puddle on the floor at the front left of the unit.
    The door seal looks ok and feels pliable.
  • Anonymous Mar 17, 2014
    G.E dishwasher, M/n GSD2000-J01WW, S/N MH854369B
  • Anonymous Mar 20, 2014
    goes directly to the rinse cycle
  • Anonymous Mar 24, 2014
    water leaking from the bottom of the dishwasher
  • 5,911 Answers
Are you washing cereal bowls or mixing bowls on the bottom rack? If so, are you placing them in front? Sudden leaks that form huge puddles can often be attributed to improper loading of the dishwasher. Most dishwashers don't have a seal across the tub front. The door closes over it and does a pretty good job of deflecting water back inside the wash cavity. However, if you place bowls in the front on the bottom rack rack they can divert the water right over the tub lip and onto the floor. This is usually the culprit that causes most leaks in dishwashers. Now, if you don't think you have a loading problem, remove the kick panel on the bottom of the dishwasher and check the drain line and pump housing for leaks. Check the door gasket for tears or cracks. Lastly, feel inside the bottom of the door with your hand. You should be able to feel the door insulation. If it is wet, then the problem could be a leak around your soap or rinse-aid dispenser. Depending on the model, some dispensers are mounted to the door with a gasket behind it. Sometimes this gasket can form leaks. I hope this helps.
Posted on Jun 05, 2007
  • Jeff Rockwell
    Jeff Rockwell Jun 15, 2007
    If you are going to rate my advice as "not very helpful" it would be nice to get some feedback on what you have tried to do to solve the problem so I may be able to help you further. I've given you nearly every cause that would create a "sudden puddle" on the floor. Barring a simple loading problem or leaky door, the only thing else that could cause a a big puddle like that is a leak in the drain pump, drain line, or a slow leak in the fill valve. Could you let me know what you have found?
I used the information from jsrock to check my dishwasher door. I found that the vent area was full of old food debris. 100% plugged! So I cleaned it out and presto changeo !! no more leak. Thanks jsrock!
Posted on Aug 31, 2007
I had the same type of problem with a Maytag DWU8240AAX. I checked the door gasket and found no tears or defects. On the advice of a local appliance parts guy, I applied silicon lube to the gasket-to-dishwasher contact, (called Sil-glyde, it has a petroleum jelly consistency & is available at auto parts stores).
The leak stopped after applying the goop, but that's obviously not a long term solution.
I replaced the gasket. The leak has stopped. For about six-eight months the door took a LOT of pressure to close, but it hasn't leaked since.
Hope this helps someone.
Posted on Feb 13, 2009
  • 3 Answers
More than likely it is the soap dispenser lock arm gasket or it could be the jet dry container o ring gasket.Either way it is an easy fix just remove the inside door and remove the jet dry tank and silicone around the threads and replace.The lock arm gasket can be easily made if you take your time and use a good gasket material,I don't believe the gasket is available through the dealer.The door gasket very seldom goes bad but its the first thing people replace.
Posted on Jun 21, 2008
I had the same all-of-a-sudden leak problem with my MDB/C-2 dishwasher. THANK YOU! It was the lock arm gasket and I found it (part # 1662429) at PartSelect.com for $3.91 + shipping. SD in Florida
Posted on Mar 14, 2009
2 Suggested Answers
SOURCE:
aborcass
  • 2651 Answers
SOURCE: Leaking dishwasher
Sorry about the delay in time in getting back to your problem if not already resolved heres what you can try. Remove the bottom panel and run through a load, to see exactly where leak is coming from, most common place for leak is through the heater hold down brass nuts. They crack and need to be replaced
Posted on Mar 16, 2008
Samsung dishwasher leaks in left bottom corner of dishwasher during rinse cycle
if it is the rear corner then you may have a leak in the drain line. take off the kick panel and see if you can tell where for sure it is leaking.
May 16, 2014 | Samsung DMR57LFS Stainless Steel Builtin...
Frigidaire dishwasher leak
run it with no soap. if you get no leaks then cut back on your soap. you may need to run washer a few cycles to get rid of excess soap.
Sep 02, 2012 | Frigidaire Dishwashers
I have a ADG450 about 7 years old, the problem is there is dirty water left at the bottom of the dishwasher after finishing the cycle and the dishes look as if they have had the final rinse in the dirty...
check the pipe leading from the dishwasher to the outlet, maybe under sink. this needs to be raise up as water will flow back into washer. Had this problem myself, felt foolish when the repair man just tied it up and left. !
Jan 03, 2011 | Whirlpool ADG450 Slim-Line Built-in...
Hobart HD-20 home dishwasher that leaks occasionaly
ck the vac. brkr. on the back of the unit, if no vac. brkr. ck the air gap on the side of the mach. let me know how you make out.sounds like the leak occurs when mach. goes into the rinse cycle dont forget to vote thanks monomoy
Jun 22, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
GE Triton Dishwasher timer may need adjustment ?
you have a clogged drain hose or a weak pump.  There are no adjustment on the timer it is what it is.
Apr 12, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
Whirlpool dishwasher leaks everywhere
CHECK YOUR HOSES FOR CRACKS. BE SURE THEY ARE ATTACHED SECURELY TO THE PUMP OULET.
THERE IS ALSO A BLACK HOSE FROM THE VALVE THAT GOES UP THE LEFT SIDE TO A VACUUM BREAK ON THE SIDE OF THE TUB. BE SURE THE HOSE HASN'T BEEN DAMAGED OR DISCONNECTED. IF THERE IS SUFFICIENT SUPPLY HOSE, PULL THE DISHWASHER OUT OF IT'S INSTALLATION AND TURN IT ON. WATCH FOR WATER DRIPPING ON THE FLOOR AND TRACE IT BACK TO FIND THE PROBLEM.
Mar 25, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Leaking dishwasher
Feb 27, 2008 | Frigidaire 24 in. PLD2850 Built-in...
Leaking dishwasher
when you state "there is water leaking out of the drain hose", then that leak must be fixed either by a new hose or to repair the hose. as far as the timer issue, i need more info.
May 25, 2007 | Maytag 24 in. PDC3600A Built-in Dishwasher
Maytag 24 in. MDB3700 Built-in Dishwasher Logo
3,635 people viewed this question
Top Maytag Dishwashers Experts
Carmen Mikulic
Mike
Marvin
Marvin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
