SOURCE: I have a GE self
Usually, there are fasteners holding the inside panel to the outside cover together. Between the two is insulation. Your two glass panels are probably held in place by tabs that are folded over or screwed in place retainers. To clean your glass, which apparently is soiled by a leak in the glass to panel and cover seal from either tabs being loose or retaining clips being loose.
You can use Oven Cleaner to clean the glass and then run them through a dishwasher, but check on the can of oven cleaner before you purchase them to be certain this product is safe to use on glass.
Hope this gets you on your way and has fixed your dilemma.
Worldvet
SOURCE: I started the GE self cleaning feature on my GE
It will stop when it is done cleaning, usually about 3 hours.
SOURCE: the oven door on our self cleaning oven will not
if you just got done self cleaning there is a good chance u burnt up ur lock mechanism.. if that checks out okay i would inspect the high limit thermostat in the rear or u might have had a control problem... though do to the heat it is somewht common for these plastic lock assembley to break or melt due to the excess of heat......u might tryin to see if u can relase it by using sometin maybe uke hanger and releasing it manually, if not u might need service.. hope this helpls let mne knoe how it goes, soory for spelling trying to get out what im thinkin ...
SOURCE: Oven door after self clean cycle won't unlock
Both the oven" ON " light and " Clean " light will flash when the clean has finished . When the " clean " light flashes , slide the latch handle to the left as far as it will go , then turn the " OVEN SET " knob to " OFF " to open the door.
