The exhaust pipe is putting and is misfiring
There are few possibilities that can cause engine misfire issues.
It can be issue with spark plugs or faulty spark plugs. Also get the
compression test done for cylinders. If any of cylinder shows low compression
then required, then that particular cylinder will cause misfire. Also get obd codes scanned, the error code will let you know
which cylinder is misfiring or all cylinders are misfiring. ----------- For your trouble shooting I suggest you to refer the help
oinks below. It has step by step details for many engine misfire issues. ---------- Click the link below:----- Ford Explorer Cylinder Misfire? http://whoisbyme.blogspot.in/2012/06/ford-explorer-cylinder-misfire.html --------- Engine Misfire codes on Chevrolet Malibu? http://schematicsdiagram.blogspot.com/2011/12/engine-misfire-codes-on-chevrolet.html --------- Cylinder 6 Misfire? http://howtobyme.blogspot.com/2011/12/cylinder-6-misfire.html ------------ Misfire on cylinder 4? http://schematicsdiagram.blogspot.com/2011/12/misfire-on-cylinder-4.html ----- While stop engine idles like cylinder missing? http://schematicsdiagram.blogspot.com/2012/01/while-stop-engine-idles-like-cylinder.html ---------- Ford Explorer 5.0L: Engine Miss? http://whoisbyme.blogspot.in/2012/06/ford-explorer-50l-engine-miss.html ----------- Oil on spark plugs and car misfires? http://technoanswers.blogspot.in/2012/02/oil-on-spark-plugs-and-car-misfires.html ------------ Can cylinder misfire Damage the Catalytic converter? http://schematicsdiagram.blogspot.in/2012/02/can-cylinder-misfire-damage-catalytic.html ------------ Car misfires and error code P0306 and P0303 is shown? http://technoanswers.blogspot.com/2012/01/car-misfires-and-error-code-p0306-and.html ----------- Chevrolet K1500 No spark, random misfire http://repairhelpcenter.blogspot.com/2012/11/chevrolet-k1500-no-sparkrandom-misfire.html ------------- 2004 Ford F150: Engine Misfire and Lean Code? http://whatisbyme.blogspot.in/2012/05/2004-ford-f150-engine-misfire-and-lean.html ----------- 1995 Toyota LS: Misfire at idle or low RPM http://whatisbyme.blogspot.in/2012/04/1995-toyota-ls-misfire-at-idle-or-low.html -------------- Toyota Corolla:
Random Misfire? http://technoanswers.blogspot.in/2012/04/toyota-corolla-random-misfire.html ---------- 2006 Ford Freestar: Misfire on Cylinder Number 2? http://whatisbyme.blogspot.in/2012/06/2006-ford-freestar-misfire-on-cylinder.html ----------------------------- This will help. Thanks.
engine sounds like misfire and is putting out tail pip
