The alarm starts a fast beep a few seconds after the key is removed from the ignition, Also, the doors will lock after a few moments after removing the key, but not opening the door. Unlocking the door via switch or pulling up on the lock, the alarm will go off (as expected from the alarm's primary function). Only way to turn it off is to leave the key in the ignition and removing the negative terminal from the battery. Key fob does not function to unlock, lock, or turn off the alarm when it is acting up.
CAR ALARM ISSUES It
can be any of the car doors not got properly locked or the door is locked but
the switch is not sensing the door locked. Open and close each door again
properly. Or
else its problem with any of switch wiring getting in contact
with alarm wiring causing it to happen. And
last thing alarm connections need to be inspected. It's getting short somewhere
in between. There
are few help links with solutions, to troubleshoot these types of problems.
I suggest going through these links. Click
the link below: ------ ------------------ http://technoanswers.blogspot.in/2012/07/alarm-keeps-going-off.html -------------- http://whatisbyme.blogspot.in/2012/04/2009-toyota-camry-hood-switch-causing.html ---------------- http://technoanswers.blogspot.com/2012/01/ford-pickup-alarm-will-not-disengage.html ------------ http://www.howtorepairguide.com/2012/11/mitsubishi-diamante-factory-security.html ------------ http://repairhelpcenter.blogspot.com/2012/01/toyota-avalon-factory-alarm-will-go-off.html ---------- http://schematicsdiagram.blogspot.com/2011/12/chevrolet-tahoe-hood-open-warning-on.html ----------- These
details will help. Thanks.
Volvo car alarm
keeps going off for no reason
http://technoanswers.blogspot.in/2012/07/volvo-car-alarm-keeps-going-off-for-no.html
Alarm keeps going
OFF
2009 Toyota Camry: Hood
Switch causing Alarm to go OFF?
Ford Pickup Alarm will not disengage?
Mitsubishi
Diamante: Factory Security Alarm will not go Off
Toyota Avalon Factory Alarm
will go off?
Chevrolet Tahoe Hood open
warning on dash and alarm sounds?
SOURCE: Acura RL 2005 Smart Key problem
Does the car lock open with the switch on the door? If it does not, it is not the key.
SOURCE: alarm problem on 97 acura tl - now car wont start
try turning the key on then taking the +side off then turn key off and reconect+
SOURCE: I was in the store
yes the starter is not getting the required pressure to start the car.as when you insert the key in ignition module the car gives command to the starter and car cranks and throw pressure to the alternater and that throws pressure with current to the sparkplugs and the spark comes and car gets started.as its the faulty wiring that gor misallighned and short circuited.as the wiring has to be checked at each point and that has to be cleared.also check out starter solenoid with starter .solenoid is located in the starter unit.
thanks.
please do rate the solution.thank you for using fixya.keep updated.
