Was heat but fan stopped working?
SOURCE: i have a 2002 dodge ram 1500 quad cab. the gauges
Check your fuses. This a common thing that can come up often if you have changed from stock stereo equipment to after market, or just because of old fuses.
Once you locate the fuse box, it should give you a diagram of which fuses go to the different lighting systems in your car. Replace them and the problem should be fixed.
If the problem is not fixed from that, then have your wiring checked throughout the truck.
