Watches Logo
Posted on Jan 10, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I can't seem to set the time on my used tag heuer watch
This is a used tag heuer professional that I bought used without instructions. I attempted to pull the crown out in the manner of most watches and it wouldn't move. Is it broke or is there something I dont know about tag watches.
  • 1 more comment
  • Anonymous May 29, 2013
    Hi, just bought a used Tag F1 watch to find the date for the crown isn't moving past the 29th. The watch itself appears genuine as it has all the relevant papers, but I'm now starting to have concerns that it could potentially be a fake! Having said that would this be a common fault?
    Model No CAC1110-1
  • Anonymous May 30, 2013
    Just to add to that - could you tell me the year this model was relised and discontuned? Just curious to know. Thanks
Arturs Kalnins
Level 3:
  • Master 2,338 Answers
  • Posted on Jan 10, 2009
Arturs Kalnins
Master
Level 3:
Answers
2338
Questions
9
Helped
1814120
Points
13579
Probably your watch has a screwdown crown and prior to attempt any settings you have to unscrew it. Some peoples fingers are stronger then others, so, try that with a pair of plyers. Cover your crown with a soft cloth and then grip with plyers(this will avoid any damage). Thread is right handed and unscrewing is done by turning the crown anticlockwise.
After setting the time don't forget to screw the crown back- it is for water resistance.
If you are unable to unscrew the crown, that means your watch is rusty and you will need watchmakers help.
PS If the watch is rusty, you can brake the crown off while trying to unscrew it. Don't panic yet, as in this case you will need a watchmaker anyway.
Don't forget to rate, please.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 30, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
650
Points
21
Thanks for the response....
I took it to my jeweller who did just that as you mentioned and now works all ok.
Thank you..
How do I set the time on a professional tag heuer ladies watch
You have to unscrew the crown once it is unscrewed can you pull it out once for the day and twice for your time. Be sure to screw the crown back in when you're finished or else you'll get moisture inside.
Tag Heuer watch losing time
Make sure the voltage on the new battery is correct. Just because a battery is new does not mean it is good. That is likely the problem.
My tag heuer 2000 chronograph professional button hard to press
Yes it would seem unlikely that the dial would cause this problem. It is more likely to be the seal if the pusher seems hard to depress. Watches should be serviced every two to three years at which time pusher seals are usually replaced. Recommend you take it to a watchmaker for a service to maintain the watch properly.
Jul 27, 2009 • Watches
7helpful
How to set the time on a tag heuer
Jan 10, 2009 • Watches
Tag Heuer Button Popping Out
If that buttun is pushbutton, then the fixing stopwasher has come off (inside watch).
If you meen the crown (winding and setting button), then setting lever or setting lever spring is damaged or broke.
Find your nearest watchmaker as both need professional repair and parts.
3helpful
Tag Heuer Ladies Professoinal 2000
Hi Dude, it's one of those things your going to cuss once you know. Just unscrew the Bezel.Thats it. Steve
Just Got a tag professional ( Previously Owned)
Hard to tell without knowing what model or caliber number (usually on back). Generally, if you pull the crown (winding knob) out all the way you can set the time. Push it ONE click in, you can set the date. Check with the manufacturers website for a book of instructions you can download.
Top Tag Heuer Watches Experts
k24674
Sean Wright
Sean Wright
Ngoro
Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
