Sewing Machines Logo
Posted on Jan 10, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Faulty presser foot lifter on a singer 2110/2112.
The presser foot will not go down when you operate the presser foot lifter.
SewTechWayne
Level 2:
Wolfpack:
An expert that has 5 followers.
  • Expert 186 Answers
  • Posted on Jan 31, 2009
SewTechWayne
Expert
Level 2:
Wolfpack:
Answers
186
Questions
0
Helped
73728
Points
377
I have seen these machines with broken presser bar clamps (something inside the head). If it is just a bind then some oil on the presser bar may work, if the clamp is broken then it is probably not worth fixing.
Why is my walking foot too high? How do you adjust a walking foot? I have a Singer 4622a and wanted to use a walking foot
Did you get a slant shank even feed foot? The Singer 4622 uses a slant shank. Sewing machines can have a high, low or slant shank foot. I would expect the wrong shank walking foot either being too high or too short from the shank screw to the needle plate on the Singer 4622. The appropriate presser feet are shown here: https://www.sewingmachinesplus.com/singer-4622-parts-accessories.php .
I hope this helps. Otherwise, check if the presser foot lifter is working properly to lower the foot.
Singer 7033, presser foot is disconnected. How do I fix it?
If the presser foot isn't connected to the presser foot shank, place the foot under the center of the shank. Lower the presser foot lifter making sure that the shank goes over the presser foot pin. Press down firmly on the screw that holds the presser foot shank until you hear the foot snap into the shank. Do not turn the presser foot shank screw. See the pictures on page 9 of the manual (page 11 of the PDF). Manuals LIb has this page here https://www.manualslib.com/manual/470415/Singer-7033.html?page=11#manual . The manual is also available from Singer on their support page: https://www.singer.com/support . The direct link to the manual is https://www.singer.com/sites/default/files/product_manual/SINGER%207029_7033_%207035%20and%209410%20Sewing%20Machine.pdf . For feet that are attached to the slant shank, you loosen the presser foot shank screw. Place the shank over the presser foot screw and then tighten the screw to hold the presser foot. If you removed a foot and the shank together, put it back on. Make sure that the needle and the presser foot lifter are in their highest positions. Push up the front side (toe) of the presser foot until the foot snaps off the shank.
If the presser foot doesn't snap into place, make sure that you have everything aligned properly. Otherwise check for damage to the presser foot and the shank. Replace any damaged parts. Some presser feet are available here: https://www.sewingpartsonline.com/singer-7033-sewing-machine-parts.aspx .
I hope this helps.
Error message on Pfaff 7570 is "bring presser foot lifter to sewing position?" Is this a fatal error or is this a procedure that has to be done before the machine will operate?
Assuming that the presser foot lifter is working, this shouldn't be a fatal error. The presser foot has to be down to sew. The lifter needs to be in the down position to put the foot down.
The manual for the Pfaff Creative 7570 is available on the product page: http://www.pfaff.com/en-US/Machines/creative-7570 . The direct link to the manual is http://www.pfaff.com/SiteMedia/PFAFF/Products/Machines/Support-manuals/Creative_7570-manual-EN.pdf?ext=.pdf . See page 32 (page 36 of the PDF) of the manual to see a picture of the presser foot lifter.
I hope this helps.
Repairing a Singer Sewing machine presser foot lifter.
Inside the foot the wires are connected to two different screws. They are obviously coming loose by being pulled.
1. Open the foot on the bottom.
2. Look where the screws are. You need to have the wires connected there.
3. Before connecting to screws: tie a knot in the wire from the inside of the foot pedal where the wire protrudes through the hole.
4. Now, tightly connect the wire to each screw. Apply bottom of bracket. Now, sew!!!!!!!!!!
How to fix a pressure foot lifter on a singer tradition
You can get a replacement Lifter from Sewing Parts Online here:
http://www.sewingpartsonline.com/presser-bar-lifter-singer-v880153000.aspx
Most likely, the screw end on the machine has broken off.
The presser foot won't go down.
Yes indeed, it is possible--sounds to me like a screw worked itself loose. However, I would purchase the service manual for your machine. As a bonus, it tells you how to make all kinds of useful adjustments.
Go to Sewing Parts Online and do a search under Singer Service Manuals; if they don't have it in stock, call or email them and they will be happy to order it for you. Generally takes two weeks to get it in stock.
I have a 9960 singer machine and am trying to use the buttonhole presser foot for the first time and I can not get it to sew T
the buttonhole foot snaps on to the presser bar, there's a little lever at the back of the presser bar that releases the foot, then put the buttonhole foot down on the needle plate & use the presser foot lifter (number 11) to lower the presser bar down onto the buttonhole foot & you'll hear a click sound when it snaps on & make sure to use the buttonhole lever(number 31) because the machine won't sew a buttonhole unless that lever is pulled down.
How do i re-install the all purpose foot back onto the machine
take the presser bar lifter & lift it up, if you look close it has a small notch under the front
place the all purpose foot down under the presser bar, make sure the presser bar notch get on to the pin that's across the top of the purpose foot & they should snap togeather
17helpful
2answers
The presser foot lifter of my Singer 9432 has disconnected
Had the same problem.
Open the cover where the light bulb is.
Follow the presser foot rod up into the machine.
You will find a metal keeper with a set screw facing the now open end of the machine.
That set screw has most likely come loose.
Since the presser foot is spring loaded to the down position leave the presser foot raising lever in the down position.
With your flat bladed screwdriver, gently push the metal keeper to it's lowest position. If it does not go easy, loosen the metal keeper set screw a bit. Lefty loosey.
Tighten the set screw on the metal keeper. Righty tighty.
Top Sewing Machines Experts
SmartAviator
SmartAviator
Are you a Sewing Machine Expert? Answer questions, earn points and help others
