Hi, You can unlock your HTC TILT safer and easier using unique unlock code. You can get the unique unlock code for your HTC TILT mobile from www.unlocking4u.com/htc-tilt/rs16wp9/ at low cost with easy unlocking instructions. All the best mate.
SOURCE: htc tilt phone
You have to get the new driver update to fix this problem, I had it for a couple of times until I got the update, now I am looking to sync my phone with the new driver.
SOURCE: How do i download GPRS settings on my HTc tilt 8900 from airtel
hi there!
I suggest that you should contact your Network Service Provider to provide you manually the GPRS settings or over-the-air settings. So that could get an accurate settings and you can enjoy using this services.
SOURCE: Compare HTC 8900 and 8925
Hi. As you can see from the following link (Comparison table between these two devices) (http://pdadb.net/index.php?m=pdacomparer&id1=861&id2=818), only difference is a 3MP Camera, which is not something small. So I think if you like, you can demand the properties you purchased at the first place. Hope this helps.
SOURCE: htc 8900 sim card unlock kode
Look for your PUK number and use it to solve the problem. Never mind the pin codes as long as you got the PUK number but remember when a sim card got lock,it can no longer be used.
