When I insert the key the incline immediately starts going up and will not stop. None of the buttons work so I have to take the key out to stop it from rising. I have tried calibrating the incline but it is still doing the same thing.
You must tried again the s.calibration, for easy diagnose, and troubleshooting.
However you must Adjust the speed sensor, test it, clean it, and tight any plug or connector, see the diagrams attached and proceed according.
2) Lube the elevation motor, the shaft + gear, test the motor itself for open or short. see the diagram attached. If you machine use RELAIS test it for dirty, or open and repair.
God bless you
SOURCE: I have a nordic track a2350 and the belt stopped
This is usually related to the control pwb which is located under the motor "hood".
You can get this part from iconservice.com by going to the replacement parts section of the site and entering the model number of your machine, Which is located on the lower frame assembly below the walk belt. After you have receieved the part you can follow this procedure to repair it.
http://www.fixya.com/support/t3807308-belt_goes_full_speed_when_started_shuts
SOURCE: I own a nordic track exp1000 series and only
# get a 12-18 volt dc battery fully charged(like one from a cordless drill)
# Make sure it is fully charged, because it won't work if not
# attach the + and - to the motor red is + and black is -
# If the motor turns slightly your motor is ok, if not the motor is bad and would need replaced
# if the motor is ok then your motor controller(the board with the metal) is malfunctioning and would need replaced.
SOURCE: Nordic Track A2250 Pro stuck inclined
My Nordic Track Treadmill A2250 is stuck on the 12% incline position and it wont go back down and I have tried to reset it by turning it off, switching the reset button to off and then on or even unplugging it several times. What would be my next move?
SOURCE: Nordictrack COmmercial 1500 console buttons don't work
http://www.fixya.com/support/r10724803-measure_voltage_in_transforme_fitnes
sincerely. Please keep me in touch.
SOURCE: our Nordic Track C2255 has
Watch the videos+Tip:
http://www.youtube.com/watch?v=TquYcOzGIw4&feature=related
http://www.youtube.com/watch?v=9G4MZh8JO2Q
http://www.youtube.com/watch?v=M7qJrRbdfBc
http://www.youtube.com/watch?v=MIIxoPtvhy8hthttp://www.fixya.com/support/r10724803-measure_voltage_in_transforme_fitnesshttp://www.youtube.com/watch?v=bF3OyQ3HwfU&feature=related
Observe as the main motor controller board has 90% of functions of the any treadmills. Now you will have powerful resultant and determine what is wrong.
good luck, sincerely G-d bless you.
E.CUADRA
MANAGUA, NICARAGUA
Tech came out, it need a new console! Thankfully it is covered for parts 31 more days! Thanks for your suggestion!
