My Bosch Classixx condenser dryer does not get warm. It stops after a few minutes and emits three sets of three beeps. Both the 'Drying' and 'Anti-Crease/End' lights flash. My Bosch Classixx condenser dryer does not get warm. It stops after a few minutes and emits three sets of three beeps. Both the 'Drying' and 'Anti-Crease/End' lights flash.
SOURCE: bosch classixx condenser dryer how
Pay me, I tell you. I am an Engineer, why work for nothing when we can rip you off, and take OAP life savings for a simple fix ; )))
SOURCE: bosch classixx condenser drier
The problem is with the lower water tank float switch, it is stuck. Take off the right hand side panel (as you are facing the machine) at the bottom you will see a spring mechanism for the belt tension. Beside this there are 2 electrical connectors. Take them off and spray with wd40 or similar. Whilst off give the plastic box they fit 2 a light tap with a hammer to free the float switch. Reconnect and try. If this fails you can over-ride by leaving the left hand of the two plugs off. This will get your machine working but you will not have an indication as to when the water container needs emptying so you will need to remember.
SOURCE: Bosch Condenser Dryer Classixx
I found this on justanswer.com, I am going to try it this weekend and I will post an update.
"Ok if you remove the left hand side panel then located at the back is the drain pump
remove the hose on it which goes up to the bottle and blow up it to make sure its clear.
If thats fine then remove the pump and clear any fluff thats in there and make sure the impeller is ok and turning fine.
Then refit and try again hopefully this should sort it out.
let me know if you need anymore info."
SOURCE: I have a Bosch Classixx Condenser Dryer which wont
Check the door interlock, this could be sticky or broken.
--- Please dont forget to vote this answer was helpful Many thanks ------
