Question about Kia Vehicle Parts & Accessories
Kia sedona heater blows cold air - Kia Vehicle Parts & Accessories
  • Kia Master
  • 14,748 Answers
Could be your thermostat is stuck opened or your heater core is bad,
Posted on Nov 28, 2012
2 Suggested Answers
SOURCE:
  • 869 Answers
SOURCE: The heater on my 1995
check the relays, fuses and thermostat. u will spot the issue in one of them.
Posted on Mar 26, 2011
My heat. blow cold air what is wrong with it it is a 2003 kia sedona ex
you have to bleed your cooling system with the heater on until all the air is purged out of it then it should heat up quickly.
Jan 29, 2017 | 2003 Kia Sedona
Heat and ac stopped working in 05 kia sedona
check that the heater control (tap ) is being turned on by the controls.. Have an accredited ac mechanic check the ac system .
Jan 07, 2014 | 2005 Kia Sedona LX
How do you flush the front heater core in a 2005 kia sedona ex?
you need to burp the system lift vehicle so front wheels are higher then back and run vehicle with heat on and coolant resivour cap off for about 30 mins
Jan 24, 2013 | 2005 Kia Sedona EX
Problem with heater blowing cold
Replace your thermostat. first of all it is the cheapest.It is probably stuck in the closed position not allowing your coolant to flow.
Feb 19, 2010 | 2003 Kia Sedona
MY REAR HEATER IN MY 2004 KIA SEDONA IS NOT HOT
MY REAR HEATER IN MY 20304 KIA SEDONA IS NOT HOT JUST BLOWING COLD AIR ANY IDEA'S
Feb 11, 2010 | 2004 Kia Sedona
My kia sedona van only heats up for a minute or
Check the metal part of the heater core lines at the firewall if you can get to them and see if one side is noticeable colder than the other. At least one of them should be hot or you have a bad thermostat. If both are hot than your hot/cold actuator inside is having a problem
Jan 10, 2010 | 2002 Kia Sedona
Air won't blow cold
Our Sedona had a similar problem, Turned out that the pipes to the rear heater had corroded and were leaking, caused some overheating which blew hot air even when the A/C was on.
Jun 07, 2009 | 2003 Kia Sedona
Vehicle Parts & Accessories Logo
171 people viewed this question
Top Kia Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Cameron Lewis
Cameron Lewis
Level 1 Expert
Kardoc
Are you a Kia Vehicle Part and Accessory Expert? Answer questions, earn points and help others
