Sony KP-46WT500 46" Rear Projection HDTV-Ready Television Logo
Posted on Jan 10, 2009
Tv goes off then red blinking light comes on
Its a Sony Wega 46 inch . I was watching it, it went off. when I turn it back on the green light blinks several seconds then it goes off and a red light starts to blink.. No picture comes on. the tv is approx 3 years old.....Is it the bulb......Any suggestions....
  • Anonymous Mar 15, 2014
    I have a sony model KDS50A2000. I changed the bulb and used the old housing. When I turn it on the green light blinks for 20 seconds then the red light blinks 4 seconds what should I do
Anonymous
Level 1:
  • Contributor 43 Answers
  • Posted on Jan 10, 2009
Anonymous
Contributor
Level 1:
Answers
43
Questions
0
Helped
9706
Points
80
Hello it is the bulb the bulb's on the Rear projection tv are ****. Buy  new tv cause it costs alot to have these tv fixed.
2helpful
3answers
Tv won't turn on. It blinks green then red.
Question shows tv is Sony KDF-60WF655.
Green light blinks when tv gets prepare to fire up lamp, check internal circuits then show picture on front screen.
Red light blinking shows some kind of internal problem during circuit check and protection got activated upon some failure.
Count the red light blink as you will see 3 second long pause and post it here to diagnose what section of tv got problem.
Did you replaced its lamp in last 2-3 years?
Thanks.
2answers
Picture & sound go on & off every sec, red light blinks 5 times
helloFive blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
shaun
1helpful
KF-50WE620 Green light blinks (no image) lamp light blinks red
Your owner's manual for the television will contain a troubleshooting section that will describe the blinking codes for the various lights, and what they mean.
However, in your case, it probably means the light is burned out.
The bulb on my TV tends to burn out about every 16 months (I watch TV for many hours per day, so your experience may be different). If your TV is still under warranty, I would suggest you contact the store where it was purchased, or contact the manufacturer.
1helpful
I have a similar problem with the Sony 60" wega SXRD rear projection TV. The green light blinks on the power/display LED and the picture comes on for a few seconds and then the screen goes black . Then the...
I believe 4 blinks is fan error. You can take back off and watch fans in particular the fan for the lamp (this one goes out the most) The TV has a sensor so it knows if the fan turns.You can take a pencil and use it to spin fan sometimes that will jump start it (not a permanent fix just a test). You can try cleaning dust off fan and replugging the connector on the wires coming from fan.Might fix it if not fan will need replacement.
15helpful
2answers
Sony FD Trinitron WEGA Standby Light Blinks, TV Does Not Turn On
Sony FD Trinition Wega KV-32HS510 Try to turn tv on -it starts then shuts off -stand by lights keeps flashing. Memory stick light flashes then goes off.
2helpful
3answers
Toshiba dlp 46 inch red light keeps blinking
42 inch Toshiba DLP. Was watching a movie and the screen went dark. The red light started to flash and kept flashing. any ideas
2answers
2answers
Tv cuts off and green light flashes
the tv will try to reboot a few times. just let i try and eventually it will start blinking red. if you could count the red blinks then i can further assist you.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
