When I plug my headphones into the tv there is no sound in the headphones and the tv speakers are still on. Is there a special setting or something to switch to headphone listening?
The way the headphone jack works is:
plug your headphones in and then mute the television using the remote.
While the TV is muted you can still use the volume up and down controls to adjust the volume through the headphones. I find that having the volume at 60-75% is more than loud enough on the headphones.
Just be careful when you unplug the headphones and take the TV off of mute, if your volume levels are still turned up you will be in for a jolt :)
You have to go in the menue, under audio, and make sure the head phone jack is turned on, it may be under the set up in the menue also
I can't find that under the audio menu or the setup menu.
I'm having the same problem. Actually, I do get sound out of the headphones, but it is very faith. If you mute the TV you can hear the sound in the headphones, which itself is a problem because mute should mute. Also, there is no setting anywhere for headphones or speakers.
