Freezers Logo
Posted on Jan 10, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kelvinator Fridge/Freezer C 340 RM does not switch off
The above cyclic defrost fridge does not switch off, freezing all the produce, no matter where the dial setting is.
  • Solveitnow Jan 11, 2009
    Thank you very much for pin pointing the fault. I was able to fiddle a little inside the thermostat/dial and that did the trick; it might not be as functional as before (the dial is currently set to 0) but it will suffice. Great job and cheers from Angelo
  • Anonymous Mar 15, 2014
    Won't stop freezing
Anonymous
Level 2:
Sergeant:
  • Expert 311 Answers
  • Posted on Jan 10, 2009
Anonymous
Expert
Level 2:
Sergeant:
Answers
311
Questions
Helped
128316
Points
888
The problem is your thermostat in your frig.the dial with numbers on it.it is no longer sensing properly and theres nothing you can do but replace.that is as long as your dial is not broken[the plastic pice with the numbers] God bless ,tom
My Kelvinator N245C fridge freezer is ok but fridge not cooling when i open the freezer door , the cold air through to fridge air outlet ok but when the freezer door shut and than no air to the fridge the...
first look for an air vent in the bottom of the fridge(a small grill on the inside wall) & make sure nothing is blocking it, like bread eg: if there isn't then unplug your fridge & let it defrost, check the drain outlet in the back of the freezer, sometimes a small item like a frozen pea gets into the drain & the water freezes around it causing the air not to return to the freezer from the fridge, to push air into the fridge you must be able to get air out or it presurises,
How do you defrost the kelvinator cyclic 300 fridge?
hi,
a manual defrost? unplug and get a 9by11 cake pan and a bunch of towels and a hairdryer. put the hairdryer on LOW only and get it positioned in the freezer (door) compartment so its pointing towards the back. cake pan in the bottom towels below. and on the floor. leave the door open about 3 or 4 inches but NOT shut so you have some air circulation. and check it frequently. make sure the hair dryer isnt pointed at the plastics at all. takes a day. pull it from the wall, remove the rear access cover behind the fridge and blow it out with a vac or air compressor too. theres an access panel inside the freezer and if your handy, your ice blockage causing that problem lives behind there in the freezer. use caution if your going to attempt taking that plate off inside. use nothing sharp.
jm
Old Kelvinator Cyclic 340. Freezer is Ice cold
Read the below :-
http://www.fixya.com/support/r3886637-refrigerator_not_cooling_enough_or_not
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Kelvinator fridge freezer is a geiger counter
something could have fallen into the fan between the two compartments
3helpful
Fridge not getting cold
unplug unit to "reset." pull unit out from wall and blow the coils out on the back of refrigerator. if that does not work- call service man to come check freon level.
Kelvinator Inox Freezer not switching off
hi! theres no funny when you smell burning please switch off the power and you che
SMELLY FRIDGE
I would move the fridge and check what is under it.
4helpful
2answers
Temperature Setting Dial in Fridge
Hi. thanks for the question. # 9 is the high, 1 is low. and it will run for 24 hrs to get on track .thanks the appliance doc
Top Kelvinator Freezers Experts
john h
ADMIN Andrew
ADMIN Andrew
David Spradling
David Spradling
Are you a Kelvinator Freezer Expert? Answer questions, earn points and help others
