The digital time is right but the hands don't move. i can move them with the dial but they don't move with the time
SOURCE: Setting the hands on this watch
press your "mode" button 5 times until it says on lower display "H-SET". Then press the "adjust" button until it beeps.
Now hold the "forward" button and the minute hand is moving.
Enjoy :o))))
SOURCE: changing the hand time only w/o changing the digital time
For Casio Waveceptor:
--- A
( ) Button Reference
--- B
Set in correct order:
1) Hand Home Position
2) Digital Time Set
1) Hand Home Position:
Press and hold A and B for 5 seconds, Press A to move Second Hand to 12: position: (if not there). Press B to enter Hour/Min set mode. Press A to move both hands to 12: position. Hold A to move hands fast, Press A again to stop hands. All 3 hands are now at 12' oclock.
Press B to exit Hand Home Position mode and enter Timekeeping Mode.
2) Digital Time Set: (hands will self set when done)
Press and hold B for 5 seconds to enter setting mode.
Press A to advance current item or scroll through choices. Press B to set item and advance to next item.
<Order of Items to Set>
GMT Differential -> Daylight Savings auto/on/off -> Seconds -> Hour -> Minutes -> Year -> Month -> Day -> Day of week language -> Auto receive -> (back to Timekeeping Mode).
<Setting each Item>
GMT Differential: Press A untill your time zone is reached (E=eastern, C=central, M=mountain, P=pacific). Press B to set (advances to next item).
Daylight Savings: Press A untill desired DST mode is reached: ("At" auto, "On" after spring change, "Of" after fall change) Press B to set (advances to next item).
Repeat to set: Seconds (resets to :00), Hour, Minutes, Year, Month, Day, Day of Week Language, and Auto Receive (on/off).
For each item, Press A to advance, and B to set.
Pressing B to set last item exits Setting Mode and enters Timekeeping Mode. Hands advance to current time.
Good luck,
Techjoel
SOURCE: Seiko Sportura SNJ007 chrograph watch instructions
Best solution is to download the ORIGINAL INSTRUCTIONS MANUAL directly from SEIKO's main website:
http://www.seikowatches.com/support/ib/index.html
SOURCE: Bijoux Terner Sport Watch Trouble
japgap has it pretty much right .... Start by pressing the Mode Key. It should change the mode (probably to stopwatch first on first press, alarm if Mode Key is pressed again, then time if pressed a third time). (NOTE: pressing the Mode Key to get action isn't about the length of time pressing the key, its about getting a "connection" when pressing!!! The sport watch doesn't have the greatest quality construction so a simple press does not always make a connection).
Once in the time mode, the seconds will be blinking, press the Reset Key to move to minutes and Start Key to advance the minutes, then Reset Key to move to hours and Start key to advance the hours. Mode Key to get back to regular operation.
SOURCE: seconds hand not moving
The roles haven't been reversed. The seconds hand for normal timekeeping is the small one and the chronograph timer seconds hand is the large one. The reason for that is that it is much easier to determine the precise second with the larger hand. It working exactly as it should. If you like having the large second hand moving all the time you will not hurt the watch by leaving it running. All chronographs work this way. Nice watch - wear it well!
Testimonial: "thats great, thanks a lot! I'm so pleased with it"
