Question about Sony FD Trinitron WEGA KV-29LS35 29" TV
My tv wont turn on ,It seem it is going to turn on and close itself
Sony triniton wow trusound tv
    Sergeant:
  • 198 Answers
Searching for tv turns off but will turn right back?
  • Service Manual of KV-32XBR400 shows error info regarding red light flash 2, 3, 4, 5, 6, & 7 times only. Each flash corresponds to different problem in TV. Please check red lighe flash count again.
Posted on Nov 27, 2012
SOURCE:
romsky79
  • 822 Answers
SOURCE: sony caption/text
go to menu scroll down click languages
Posted on Jun 04, 2009
SOURCE: SONY TV KEEPS TURNING ITSELF OFF!!
Its the BULB people! You need to change it every 3 to 5 years! I have had my sony 55" for 6 years... I had Best Buy come out 3 years ago, changed the bulb... it worked fine. Just started flasshing and shut its self off and back on again. Time for another bulb.
Posted on Nov 22, 2008
SOURCE: sony triniton tv turns on and immediately switches off on it s own
We had a bad storm and lots of lightening. After that my tv (which is plugged into a surge protector) would turn on and then immediately turn off. I unplugged the TV from the surge protector and plugged it into a different outlet and it works now.
Posted on Apr 28, 2009
crazyhcris82
  • 34 Answers
SOURCE: How do I tune in Sony Triniton tv please
Hello
The first thing is to try going in the tv's menu
It should be similar to this:
Menu>setup>channel setup
once you find something similar, run the channel setup and it should add in the channels
If that doesn't work, screw on the cable wire, unplug the tv for a good few minutes, then replug the tv and it should automatically scan
Hope this helps
-Chris
Posted on May 01, 2009
  • 8 Answers
SOURCE: the tv/timer button is flashing and tv will not
if u r the macanic of TV then check the entire power supply n standby circuit
Posted on Mar 14, 2010
HOW COME MY SAMSUNG PLASMA SRS TRUSOUND MODEL#HP-T4264 YEAR 2007 TELIVISION WONT TURN ON ,THERE IS NO PICTURE
More than likely a capacitor on the power supply board inside the TV has blown. (it looks like a split mushroom).
Sep 07, 2014 | Televison & Video
My Sony triniton tv won't power on because the
Every set has a standby power supply that runs 7/24 when set is plugged in---it means in this case a main power board or something associated with that is not working, Set is not making it from just standby to full on.
Dec 23, 2012 | Televison & Video
Sony triniton model kb-36xbr450 keeps turning off by itself
There is some short circuit with the main board of this TV. Contact any experienced service technician to get it repaired. It is a skilled work, that a user can't do.
Aug 10, 2012 | Sony KV-36XBR450 36" TV
Why does the sony triniton 40in not turn on but the power button flickers red
Is it blinking a code? * * * * * * * * * * * * This would be a 4 flash. Count them and post the flash code.
Mar 17, 2010 | Sony FD Trinitron WEGA XBRKV-40XBR800 40"...
Sony caption/text
Jun 04, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
No cable channels at all on old Sony Triniton
make it sure that the coaxial cable has its own signal! if your tv has a raster (sometimes blue) and it says that the tv is good, but if there's no channel at all then the problem is in digital converter or the connection of the coaxial cable comes from..you can also try auto programing but if the problem still occured then contak your cable subscription channel
Apr 03, 2009 | Sony KV-13M10 13" TV
Tv turning off
Hello
Sony FD Triniton Wega KV-36XBR400 service manual has no info for 11 times flash. It has info up to 7 falshes. Please count again. Error codes are in below pictures...
Regards,
Aug 27, 2008 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
Sony triniton KV- XG29M30 WONT TURN ON
I had a similar problem a few years back . I purchased a new on/off switch from Sony and that seemed to fix things.
Alleluia
Jan 05, 2008 | Televison & Video
Sony FD Trinitron WEGA KV-29LS35 29" TV Logo
147 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
