SOURCE: PROBLEM WITH COLEMAN DGAA070BDTB FURNACE KICKS ON
you have a bad ignitor or gas valve call your local heating repair company
SOURCE: Have a coleman furnace and
There will be a small tube that goes from the induction blower housing to the switch itself. Try to blow and **** through this tube with it attached to the switch. If you hear a click on the inside of the switch, it is good, if not, then it needs to be replaced. Another thing to try, take a small wire or paperclip and poke through the hole that the hose came off of on the housing, sometimes this gets clogged and will cause the same problem. Other than that, it will be a blocked flue or the inductive blower itself not performing properly. Hope this helps and good luck!
SOURCE: need yo connect thermistat to coleman model
Here is a list of each common terminal and what their commonly used for. Alsolisted is what colors are commonly used. NEVER ASSUME these are what youhave. Verify all your wires by following each to each piece of equipment. Thiswill help you to be able to match your equipment with the terminal.
Here is the rest of the tip that I wrote...
Thermostat Wiring and Terminal Designations
heatman101If you have further questions, then comment back to me...
I would not try to do this, in the uk you need to be properly certified to work on such items. If you make a mistake you could blow up.
