Here is the service manual for that unit.
Hello Angel BriBri, that's a great question!
I see that you would like to put your Frigidaire washer into test mode and you do not have the available buttons listed on the average test. Could you please provide me with your model number? You can usually locate the model number on the serial tag which can be found on the door frame of your washer. With that information I can look over your manual to see if I can locate the diagnostic mode. I look forward to assisting you. -Matt
Hello &
Welcome to FixYa
Someone accidentally put it into TEST mode and to get it out of
the test mode follow this:-- Unplug the washer for 4 minutes and then plug it
back and press start, the display should go daft. Press start again and the
display should settle down. Now press the on/off button and the start button at
the same time and hold them down for a few seconds until the display shows
d-end or d-off. Please get back to me if you have any other
questions.
Kevin
The washer must be empty and the control must be in theOFF
state before pressing the touch-pad sequence to start the test.
Starting the Test Mode
?Close the door.
?PushCONTROL/ON(if present on this model).
?Select theDRAIN/SPINcycle.
?SelectNO SPINby pressing theSPIN SPEEDtouch-pad.
?PushPREWASH OPTIONfour times within five seconds. (If
PREWASH OPTIONis not present on this model, pressEXTRA
RINSEfour times within five seconds.) C:00 will light up on the
display.
If the Starting procedure fails, push thePAUSE/CANCELtouch-pad,
then repeat the starting procedure.
Test Program Control
In order to advance to the next step of the test procedure, push
PREWASH OPTIONtouch-pad two times. IfPREWASH OPTIONis not
present on this model, pressEXTRA RINSEtwo times.
?Close the door.
display.
