Vehicle Parts & Accessories Logo
Erika Garcia Posted on Nov 26, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Just replace our neutral safety switch and it worked good for a while and now in the morning i start my car and can drive around as long as i need but as soon as i turn it off i cant turn it back on f
1996 mercedes e320
Christian Krentz
Level 3:
  • Mercedes-Benz Master 694 Answers
  • Posted on Mar 02, 2014
Christian Krentz
Level 3:
Answers
694
Questions
Helped
159978
Points
1404
Bad connector check the pins on the harness they have to b corroded clean them and then put dyelectric grease on the pins for the connector this should end your issue
2 Related Answers
Anonymous
  • 463 Answers
  • Posted on Feb 22, 2011
SOURCE: My 1996 Grand Voyager runs
You didn't mention any trouble codes. In 1996 all vehicles manufactured in the U.S were required to install the second generation OBD, also refered to as OBD II, to insure that a standard scanner could be used on all vehicles.
It shouldn't be a fuel problem with everything you've had done.
I don't believe it's an emissions problem, because, although emissions can cause a vehicle to stall it usually gives a bad idle and poor acceleration among other things.
Because you don't mention bad idle, loss of power, or no restart we can safely say it's not an emissions problem.
The only thing left that I can think of is an electrical short. I would start with having both ends of the auto shutdown relay checked for a good connection and have the contnuity checked.
Secondly, I would ant to have the wiring in the steering column checked for the same thing, in particular around the ignition. I am very sure your problem is electric.
I'm very sorry your having these issues and I hope this will help you solve them.
If you have other questions please feel free to leave me a comment, and I will get back to you ASAP.
Thanks, Donnie
Anonymous
  • Posted on Jul 25, 2012
SOURCE: how to replace neutral switch 1998 honda accord
The neutral safety switch is located under the clutch on all vehicles that have manual transmissions. The are designed to prevent the car from being started while still in gear. Some models are adjustable and can be tightened or loosened to make them work. Others must be replaced as a unit. Their are several steps to checking out the neutral safety switch on your vehicle. The following is assuming you have a shop or garage that you can work
Where is the neutral safety switch on an 07 Nissan Xterra
The neutral safety switch on an automatic transmission (also known as a park/neutral position switch or neutral start switch) is usually mounted to one side of the shift lever (top of the transmission), around the base and near the bottom (front-wheel drive models); other models have the switch attached to the left
2answers
Why do I have to wiggle it around in neutral to get it to start again?
sounds like the neutral safety switch. i have replaced a few on ford trucks. after a while they tend to wear out or get out of adjustment. but if you wiggle it around and it starts. my guess is the neutral safety switch. you didn't specify what kind of vehicle you have but there are a lot of videos on you tube that may show you how to do this. good luck
2007 impala won't start sometimes
The most likely problem is a failed safety switch in the transmission. It will only allow the engine to turn over when in "neutral", or "Park". Next time it happens try moving the transmission selector through the full range of travel a couple of times. If this cures the problem, you may need new switch.
1helpful
2004 ranger will not start in park
Sound like a problem with the Safety Neutral Switch, its possible that need adjustement. Keep in touch.
Hope this helps.
1helpful
My mazda MPV 2000 wont start. I was starting the car in neutral for about 2 weeks, and about 3 times I started it doing a bit pressure from "neutral" to drive, but now nothing works. I still...
I had the same problem a month ago. my van would not start at all. I replaced the starter and ignition switch and still does the same thing, but when I replaced the neutral safety switch,it has been working ever since. Try replacing the neutral safety switch. it's located underneatht the battery. I paid almost $70 dollars from the dealer.
3helpful
Need location of neutral safty switch on my 1990 cadilac broughm 350 engin e
The neutral safety switch is located on the top and toward the base of the steering column almost to the floorboard.
To remove or install the neutral safety switch be sure to place the shifter in the neutral position, then dis-connect the wire connector at the neutral safety switch, then remove the securing screws and then remove the neutral safety switch.
Install the new neutral safety switch and do not over-tighten the securing screws, then remove the alignment pin and re-connect the wire connector to the neutral safety switch. (be sure not to remove the alignment pin until the neutral safety switch has been installed)
Check to be certain that the vehicle only starts in "Park" or "Neutral". Here is an image to help assist you, and let me know if you require any further assistance.
3helpful
2answers
Bronco wont start 88 ford bronco just replaced tranny and now won't start. i've hooked everything back up but one of the wires to the transfer case bc i broke the plug in. any ideas why it wont start...
The neutral safety switch is located on the side of the transmission and it is usually attached behind the shifter linkage and it is secured with two small bolts that can be loosened up to allow for adjustment of the neutral safety switch.
To adjust the neutral safety switch place the transmission into neutral, (block the tires) there is a notch or and indent marker on the housing of the neutral safety switch that should be lined up with a line on the face of the collar that is around the shifter detent shaft, and if they are not in alignment then loosen the two bolts that secure the neutral safety switch and then turn the neutral safety switch until they are aligned and then tighten the securing bolts to the neutral safety switch, and then test the starter. If the starter fails to engage then either the neutral safety switch is faulty, the neutral safety switch has been by-passed all this time and the by-pass (I will usually find things like a paper clip shoved into the vehicles wire connector with electrical tape around it) has fallen out of the wire connector from the vehicle wiring harness, or the battery just went dead. if you have the neutral safety switch from the old transmission still available try using it to test the neutral safety circuit. I have provided you with an image to help assist you adjust the neutral safety switch.
1992 buick regal won't start in the mornings after sitting overnight. when i try it in the early afternoon it starts right up
Next time it happen.
Put your foot on the brake,shift the gear selector to neutral "N" and start the car.
There is a switch call neutral safety switch and it can be intermittent.
If you can start the car in "N" and not in "P" then neutral safety switch is at fault.
Replace it as soon as possible to prevent damage to the wiring and transmission computer.
Top Mercedes-Benz Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
ADMIN Andrew
ADMIN Andrew
Are you a Mercedes-Benz Vehicle Part and Accessory Expert? Answer questions, earn points and help others
